Old 12-22-2011, 04:38 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Check this page: http://aaawelder.com/johnboat.html
Old 12-22-2011, 04:39 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 711
You will find transoms are raked on just about anything, reason being waves are less likely to splash water into the boat. About 13-17 degrees commonly.
Old 12-22-2011, 08:15 PM
chris3298 chris3298 is offline
Rep: 10 Posts: 26
You know I was just thinking that, I've got a 15ft with a 50 and because it's over powered and heavier I do have to kinda be careful as to not have water come in the boat when slowing down. Mine does seem to be more raked back more then other boats i have seen.
pistnbroke,
I am really interested though in playing with this program so what you're saying is I can design this boat and then print my design out through a regular printer and then trace the sides out on the aluminum and I'm set?
Thanks
Chris
Old 12-22-2011, 08:16 PM
Rep: 10 Posts: 26
Originally Posted by daiquiri View Post
I'm seen that website to and wasn't crazy about those designs, I can see how this maybe a good design for lakes up north but not for what I want here.
Thanks for the link though
Old 12-22-2011, 11:04 PM
Rep: 10 Posts: 26
I've come to terms I don't need a dam computer program to tell me how to be build a boat, There so many guys down here in the swamps that don't use computer programs. I'll just get me some some paper draw it out go with my angles I want on the transom and sides and build the dam thing.
Programs are harder to work then actually building the dam boat. Theres so many off road rock buggies that are built without a program i sure as hell can build this with out it
Thanks for the help everyone
Old 12-23-2011, 01:33 AM
Rep: 246 Posts: 711
You really need to go back to school to become proficient at these CAD programs, not worth it for a small one-off project. The main thing is that your design works on the water, not how sexy it looks in 3-D.
Old 12-23-2011, 01:38 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
2 things ..the standard transom angle is 15 deg ...you just put it into Carene and there ist is ...BUT if you are not up to speed on things like this should you be building a boat yourself ,,,you must deceide on metal thickness and re enforcment etc to make a safe boat,,I did one of those flats punt things in carene in about 6 min last night But I have done it a 100 times.... go play with it your life .....If you want the panels a good fit to weld easy then you need the freeship developments this is not cutting bits of pipe and using a tape measure these panels got to fit first time ...
Old 12-23-2011, 01:38 PM
Rep: 10 Posts: 26
Thanks I'll try playing with the program a bit more
Old 05-15-2012, 07:46 AM
Brayan Brayan is offline
Rep: 10 Posts: 5
You can pick up a decent used 12 - 14' aluminum boat for a cpl hundred add a small trolling motor and a trailer and you are all set check out Craig's list your local paper etc.
Shop fronts London
Aluminum boat plans? mtowers Boat Design 5 07-30-2011 01:04 PM
aluminum speed boat plans ggdn Boat Design 3 08-12-2009 05:54 AM
small boat plans in aluminum dandude Metal Boat Building 7 01-21-2006 04:15 PM
Aluminum Jet Boat Plans Trigger Metal Boat Building 16 07-11-2005 01:25 AM
Aluminum Jon boat plans Matt F. Boat Design 30 08-31-2004 12:41 AM
