Old 03-21-2009, 02:09 AM
carlos bairo carlos bairo is offline
Rep: 10 Posts: 41
aluminium windows fabrication
wondering if it poisble to fabricate my aluminium windows from extrucion or chanal and the best way to build them on a radius corners of 45/90degree the boat is aluminium under constrution. welcome with any other advice or idea , looking to my budget ready make wuindows will be very difficult,looking at aus $3.5ooo. regards carlos ,,,,,,,,,,
Old 03-21-2009, 03:27 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
carlos,
Do you want them to be opening, if not there is no problem, it is an alloy boat, so make the frames out of alloy plate, cut out to suit.
The glass can be set inside the cabin by making internal framing and Sika them in (from the outside).
Old 03-21-2009, 09:41 AM
Rep: 10 Posts: 41
landlubbr'''''' thanks for you sugestion,the problem to make out of plate in my case is the waste of plate on the total 8 off wuindows that whose the case on the other 21fut alloy boat that i build beafore.more then half 1200x2400plate waste. only 2 off windows will be opening ,that the case i am looking other solucion with the fabrication on extrutions or chanel . regards CARLOS
Old 03-22-2009, 11:00 PM
Landlubber's Avatar
carlos, if the boat is a sea boat, the cutout plates can be made into deadlights, that way there is no waste.
Old 03-23-2009, 06:36 AM
Rep: 10 Posts: 41
landluber''''''thanks for you response and help to find the best way to build the frames you got a god idea but my consern is the look of the boa cavin,theboat that i buiding is a tug 21/.6fut alloy TITAN from G L MARIN desaing ,and as you know the windows in a boat make the god or bad style. i amlooking to kept in toch to exchange ideas and progects kinds regards carlos bairo
steel fabrication yard mikeskip Metal Boat Building 7 01-06-2009 09:52 AM
Electric Outboard Fabrication rogerstrube DIY Marinizing 6 11-26-2008 09:51 PM
Spar Fabrication ? GOTTABSOMEWHERE Boat Design 5 08-13-2008 04:52 AM
Windshield fabrication nalbercj Boatbuilding 0 06-29-2005 10:23 AM
plug/mold fabrication cfox Boat Design 8 06-23-2004 11:55 AM
