Old 02-06-2006, 06:54 AM
daedong daedong is offline
Rep: 14 Posts: 27
Aluminium Welding
I know this question has been asked many times but I am still confused. I wish to build a small aluminum boat about 5 to 6 metres I have looked at kits and plans and they all recommend MIG welders in the 250amp range. I have just ordered a 200amp AC pulse TIG. Will this do the job?
I do have a 220 amp MIG but have never welded aluminum. I Understand it is easier to weld aluminum with a TIG is this true or not. Should I set my MIG up for aluminum and start to practice or wait and master the TIG.
Houseboat
website
Old 02-06-2006, 09:20 AM
trouty
Mastering Tig
Mastering Tig takes an awfull lot of skill - but it also is very neat and produces a very acceptable penetration weld in the hands of a capable operator.
Mig on the other hand is not nearly as neat as a GOOD tig welder can produce - but is very acceptable for boat building purposes you describe.
I built mine with MIG.
Not ALL Mig welders feed aluminium wire well - you need for example a different insert inside the feed line.
You also use argon gas.
You need to practise a fair bit to get it right.
There are special techniques for Mig in aluminium.
50% stitch backwelded and regular rotation from port to starboard side to avoid warping hull lines..inducing hull twist etc.
Fillet welds for transom etc..
Lots of cleaning / grinding and re welding but end result is a good boat!
You can do it with MIG.
You can do it with TIG but will take much more "experience" believe to produce a better result than MIG.
Mig worked for me - practice practice practice.
Cheers!
Old 02-06-2006, 09:22 PM
Rep: 14 Posts: 27
trouty
Did you have much experience with the mig before you built your boat? Did you build it from scratch or by a kit.
Houseboat
website
Old 04-19-2006, 09:05 AM
wingsails wingsails is offline
Kim Prentis
Rep: 10 Posts: 19
I agree with Trouty, Taught myself mig then went to tech for more info and tig is SLOW and after seeing my friend use a tig to build an offroader radiator tank which took nearly 10 hours and a full bottle of argon (here that AU$ 120), I am sure could have done the same job and polished it up in 2 hours and a 1/10 th of the gas. Mig for me even if you do get a glitch it doesn't take long to cut out and redo. I find it easier to weld ally than steel now but maybe more practise
Old 06-05-2006, 05:16 PM
stonebreaker stonebreaker is offline
Rep: 42 Posts: 438
Since you've already got the mig welder, I'd look into buying a spool gun or even dropping the big money and buying a push-pull setup. Then take a welding course at your local trade school to learn how to do it right. As mentioned, mig has the advantage of being LOTS faster than tig.
I didn't have that much trouble learning to tig aluminum, but I had a good teacher. It does take some time to learn, however, and you have to learn to scrub every bit of anodizing and surface oxidation off the aluminum or you get a bad weld.
Stonebreaker
Ph.D in Redneck Engineering - Piling it higher and Deeper.
Welding Iron Hammersmith Metal Boat Building 3 04-25-2005 01:43 PM
Welding aluminium. ted655 Materials 20 01-22-2005 11:34 AM
welding aluminium captain butch Boatbuilding 9 12-31-2004 03:21 AM
New to welding Aluminum captain butch Metal Boat Building 22 11-28-2004 08:35 AM
Welding Wire Arrowmarine Metal Boat Building 2 09-03-2004 02:01 AM
