| aluminium sanding with grinder and wax?? Now I read in a magazine the other day that when they sand the welds down they use wax with the grinder sanding disc??? is this true if so why and what type of wax do they use and whats the benefit from using it any help would be great |
| Aluminum in particular clogs files, sand paper, and anything else that abrades it. The sanding material fills up with aluminum (which heats up momentarily and becomes tar-like in consistancy) long before the grit wears out. I'd guess that coating discs with wax allows the aluminum to fly off in the same way steel would. I've never heard of it, but apparantly someone put their thinking cap on. |
| Yes, any tool with which you cut aluminum. The first thing that "Googled up"... http://www.nolansupply.com/superflui...+Wax+Lubricant Any shop that shapes aluminum has these, or another brand, next to every tool. |
| Well I gave it a go last nite welded up some Ali and sanded down with wax and wow what a smoother sanding job!! After all these years not using wax only on my saw now on my Sanding disc. Huge difference |
| I have thrown away a few die-grinder bits for being too lazy to go get the wax! Glad it worked well for you. |
| We would never use wax on an aluminum sanding disc or die grinder bit, Yes certainly there is less build up but if you should get any wax on an edge that needs to be welded (or painted) you would have to do a superlative job degreasing the edge to get a 100% weld. The method is to use a very coarse grit for sanding or grinding discs, say 40 for first removal then down to 60. You will get a very smooth finish, Use a rigid disc for fast removal then a flapper style for finer work. I employ about 6 guys who are grinding and welding aluminum 8 hours a day, we dont own any wax. |
| I only use after all welding was done, and cleaned up just before painting it seams to work good for my job seams to sand a lot quicker and with less effort, but I could see your point if you need to weld and the wax is all over it will keep that in mind when I do my welding and sanding. |
| I want to be your disc salesman. A little wax goes along way. Your right, you don't want to fill the weld joint with wax. A little touch to the disc makes it cut twice as fast and last many times longer. Welderbob |
| Candle wax? Floor wax,Johnson furniture wax I don,t have welding specialist shops here. But if its not going to be rewelded and its a non painted part, perhaps it could be considered. Would it help cutting Zincs in half with a 4 inch cutting wheel? Its damn near impossible --quicker with a coarse hacksaw. |
| just a normal bar of hand soap dose the trick! |
| Teak wax | Nick F | Wooden Boat Building and Restoration | 2 | 10-05-2009 01:48 PM |
| pva or release wax | wave dancer | Boatbuilding | 7 | 11-12-2008 02:17 AM |
| Mold release wax | mikereed100 | Fiberglass and Composite Boat Building | 11 | 10-06-2008 02:39 AM |
| releasing wax--anything else | Frosty | Fiberglass and Composite Boat Building | 6 | 01-01-2007 03:28 PM |
| How Much Wax? | Swimpy | Materials | 7 | 08-18-2006 12:25 AM |
