Old 08-07-2008, 03:20 AM
GoldenTriangle GoldenTriangle is offline
Rep: 10 Posts: 3
Aluminium Mast Section Extrusions
Maybe I haven't gone back far enough in to the archives, but so far I haven't been able to find a post that deals specifically with aluminium spars.
I was fascinated to read the information on extrusions in this section.
I am trying to source a mast section for a friend in China. Unfortunately his rig fell over the side and circumstances did not allow for its recovery.
I see some of you guys already have experience in this field. Anyone aware of a source for mast extrusions in China?
I am also playing with idea of suggesting a junk rig to him as an alternative solution and the possibility of a prefabricated tapering mast section, for instance as used in lighting gantries, has also occurred to me.
The possibility of using a welded tube seems to be suggested by Michael Kasten for use with his designs (one of which does sport a junk rig). But I couldn't find any of the specifics on his website.
Ideally we can find a standard mast section from which we can then build a new rig.
The boat is approximately 30 feet, but the original rig was cut down somewhat (the design was in fact scaled up, and the rig cut down as well).
The rig was originally very underpowered and inefficient (hence the need for it to go, enhanced by the quick release hook ends on the rigging screws....)
Any suggestions would be welcome.
Old 08-07-2008, 04:03 AM
Previous Member
Rep: 0 Posts: 0
an Aussie guy gets them made there for very little
he guards the source carefully
if you google dave lambert brisbane he may have a website, maybe not, and seeing as you are in China he may tell you which factory he deals with
Old 08-07-2008, 04:29 AM
Rep: 10 Posts: 3
Thanks for that
Mmmmmmm, that sounds promising.
Thanks for that!
Old 08-12-2008, 06:40 AM
suichan suichan is offline
There are serveral alum. factories in China can make mast extrusion. The one you mention probally in Tianjin which very close to Beijing.
The website only in chinese.
http://kls-tj.cnal.com
You can try to contact them. But I don't think they would just make you one mast. Good Luck!
Old 08-12-2008, 07:45 AM
Rep: 10 Posts: 3
Suichan get in touch sometime!
Hi Suichan 中文不是问题! My qq is 23658378 if you get a chance add me.
I don't see anything on this company's website to support your claims.
Perhaps you should suggest they contact me directly.
Regards.
Old 09-01-2008, 10:52 AM
Jack Daniels Eq's Avatar
Jack Daniels Eq Jack Daniels Eq is offline
Shockwave
Rep: 11 Posts: 50
Some Polynesian cats have free standing aluminum light standards or poles that work very well. Cool hand Luke II
BR>Jack
Old 12-10-2008, 09:27 AM
Stillbuilding Stillbuilding is offline
Rep: 10 Posts: 6
Me too
I am looking for a China company which will make mast extrusion also. Let us know if you have a good contact.
Advanced aluminium extrusions for boatbuilding? simon Metal Boat Building 29 02-20-2008 03:10 PM
Aluminium Mast superslooper Boatbuilding 4 11-09-2007 11:24 AM
Midship section drawings for aluminium catamaran rkpshenoy Boat Design 6 06-13-2007 02:28 PM
aluminium wing mast extrusion joshy7 Materials 0 02-01-2007 06:27 AM
Octagonal wooden mast section: glue Scott Carter Wooden Boat Building and Restoration 5 11-08-2006 08:07 AM
