Old 10-08-2006, 08:01 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Adding Headroom to Thom Thumb 24
The steel Robert's Thom Thumb almost has enough headroom for me, almost.
I would like to add 1.0" to 1.5" headroom while avoiding raising the cabin hieght.
Could I make the top horizontal member of the floors of wider stock and then recess the cabin's sole the desired amount?
Thank you.
TGoz
Old 10-13-2006, 01:25 AM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
You know.....
EI=EI
If you're replacing the floors with the same material, just make sure the section modulus (I) that you're left with is equivalent. Get a highschool student to figure it out for you (figuring that out may not be as fresh in your mind as it is in theirs). Principle moments about the centroid, high school math.
cheers
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 10-13-2006, 11:06 AM
timgoz's Avatar
Thanks JDF.
TGoz
adding more ventilation James Francis DIY Marinizing 4 08-16-2006 07:38 PM
Adding bulkheads Ok J Fiberglass and Composite Boat Building 5 05-03-2005 12:45 PM
Can I have a thumb nail lakerunner Option One 0 01-09-2005 01:40 PM
Standing headroom in a 12 footer... Sean Herron Boat Design 2 10-26-2004 11:03 PM
Headroom in a mini transat, like - 22 footer... Sean Herron Boat Design 4 05-09-2004 02:40 PM
