| Adding depth to steel barge Our barge is 12' wide by 32' long by 2' deep. I would like to upsize but have been unable to locate suitable. Any opinions on adding another 2' of depths to this barge. It was constructed using commercial steel trusses inside. My thoughts would be to simply weld another truss on top of the exisiting to double it's depth? |
| You ned to watch the scanting sizes, plate thickness is important sound like you need some local pro advice.
| Local professionals are rare in a small town. I was hoping that I could find some answers here. My top deck plate is 1/4 " I am not sure waht scanting is can you elaborate? This is still a very small barge and is used mostly to move construction materials. Loads will never exceed 15 tonnes even when it is enlarged. |
| They will mate, they will - if you've got the capacity you'll use it! No matter what you say now sometime in the future you'll be pushed into it (pressure of work). If the stuff carried is such that it's weight never changes it must be a solid piece of gear (roof trussess?) In which case do you need to be deeper? Remember 2 feet deeper may mean difficulty in getting into the dock to unload (you state you come from a small town, is it so small that the dock size is limited? I'd say yes, so take a look!) If your not sure what "scantlings" are I'd say your not really a 'sailor' but a 'builder' who lives near the water, and like the rest of us is trying to get something done as cheap as possible. Nothing wrong with that, your in business are't you? But be careful the water will kill you as soon as look at you, take another look AND if you REALLY need this extra size employ an Expert it'll work out cheaper in the end! It may even save your life! |
| How to build a steel barge | Big Builder | Metal Boat Building | 24 | 05-31-2010 04:58 PM |
| 300' x 80' x 18' Dumb Barge | sbdlm | Metal Boat Building | 3 | 06-16-2006 02:35 AM |
| 40 foot steel board | JamesH | Boat Design | 0 | 10-05-2005 03:33 PM |
| 255' Three-Masted Steel Barkentine for sale | Yachting | Marketplace | 0 | 02-09-2005 10:35 PM |
| foam filler for steel barge | Sue Fox | Metal Boat Building | 5 | 11-29-2004 08:18 PM |
