  #31
Old 08-05-2006, 06:59 PM
globaldude globaldude is offline
court jester
Rep: 10 Posts: 110
Thanks Mike, Wynand, yeah thiners is a bit expensive to be blowing away into the air !.
I think the meths would be a good finish "rinse", with comp- air spraying, is it safe [ for the seals etc ] to put through an airless ??
I'll go for the reusable idea periodically pouring off "good" stuff & cleaning out the crud .
Wynand does what you say, re air in the epoxy, hold true allways ?. I mean are there times when I can use my comp air spray gun , or don't ever with epoxy !?.
If that's the case I'd best buy myself an airless sprayer ---- bugger !, can't keep useing ya mates one eh !! .
How about boat design definitions JonathanCole Boat Design 55 01-24-2010 04:48 PM
Luhrs T-29 (1995) diesel inboard converted to outboard Iya Boat Design 13 03-07-2007 06:48 PM
Jet Drive Jet Drives 15 12-18-2006 09:51 AM
Stepped Hulls Ryon Macey Powerboats 53 08-01-2004 10:44 AM
Steel and plywood hull? pdvjak Boatbuilding 1 02-01-2003 11:12 PM
