| 49' steel houseboat repair Hi, I am considering the purchase of a 49' x 21' steel pontoon housboat. I don't know a whole lot about about steel or boats, but this would allow me to fufill a lifelong dream of living on the water. The boat has 700 sf of living area with 100 Amp shore power and continuous holding tank pumpout. It has a 6' x 47' center pontoon and two 3' x 44' side pontoons, I estimate it displaces about 25-30 tons. If I were to buy this boat it would be a liveaboard spending most of it's time at dock in a river running 2-3 mph. The 1942 Navy surplus engine is not currently operable. The seller claims the pontoons are 5/16" steel and looking at the end welds, this appears to be true. It was homemade in 1992 and has been sitting in fresh water since then, does not appear that paint or zincs have ever been applied. It is my understanding that once a steel hull loses 20% of the original steel, the structural integrity becomes compromised. It appears to be approching this point. I had a former comercial diver inspect the pontoons. his "guestimate" was that the pontoons sounded solid and that there is about 1/32" of corrosion on the outside. He handed me a rust flake and it looked more than 1/32" to me, but it broke when I tried to measure it. Because of its 21' beam, I can't lift it at any of the local boatyards. A shipyard bid about $23,000 to drydock, blast and paint the pontoons with anticorrosive paint. I am getting two opinions on this: The minority opinion is that if this is essentially going to be used as a floating home, I can have the pontoons filled with foam and it will float for another 20 years. The majority opinion is that the pontoons can be saved, but I have to pay to have the shipyard paint them soon, and it is never going to be cheaper then the current price. It is my understanding that if I paint it, I preserve the existing stuctural integrity for about 15 years, when it will have to be lifted and painted again. What I can't get a good understanding of is what will happen to these pontoons over the next 15 years, if I fill them with foam and don't paint them? Can anyone here venture some opinions? Thanks, Sam |
| sounds very much like you should get an ultrasound, this gives a very accurate measure of the steel thickness , same as ships surveys have(compulsary) A rust flake will always appear thicker, , much thicker Anyway if here are no deep pits, evidence of corrosion, thats a start, IF the hulls are airtight, they may be sound, BUT I would not buy that boat unless you can get that thickness test done After this, and all ok, then a blast, , then 75 microns DFT zinc, then 300microns dft high build epoxy from Devoe, then it could very well last 50 years 25 microns is one thou ) you can apply the high build in one hit, 15 double header passes using a wet film gauge |
| Thanks for the response, Sounds like another vote against the foam. Just to be clear, there is a layer of corrosion over the entire underwater area of the pontoons, estimated at 1/32".(400 micron) There is pitting, I might guess maybe an additional 1/32", but I am not very experienced at judging. It doesn't appear to be leaking. I did not know about rust flakes appearing much thicker, thanks. I have inquired about ultrasound testing, my understanding is that they only do a limited number of spot checks at various points. Is this a valid means of assessing the rest of the pontoon/hull that wasn't spot checked? It looks like Devoe makes several high build epoxies. Any recomemdations on the best one? The advice I have been given has been for coal tar epoxy. Devoe makes something called Devtar 5A which does not contain coal tar but claims to be superior to products that do. The shipyard I have been discussing this with has been particularly unforthing about the particulars of the paint and how it will be applied. The bid just read: "Sweep blast to SP-7, one coat of anticorrosive paint". They did say they would provide the manufacturer's product info. I would have thought that for $20,000, they would be more accomodating, but I guess they realize that if I want the pontoons painted, my only option is to have them do it. Coming from a position of ignorance, I am reluctant to request a detailed bid specifying exactly how the paint should be applied, without having a clear understanding that my spec is significantly better than what they ordinarily do. These people do deal with oceangoing tugs and barges, so I assume they know something about what kind of paint works good, but you never know... Having said that, Does the paint last 50 years or just the hull, when it is painted every 15 years? Finally, assuming that there still is 20% left of the original 5/16" (8mm) steel, anyone care to try to explain what will happen if the pontoons are filled with foam, but not painted? Not to belabor this second option, but the seller seems to think that is the prefered strategy. So far, I haven't been able to get a compelling explanation to take back to the seller as to why this might not be a good idea. Anyway, thanks Lazeyjack for providing specific information. Sam |
| If you have 20% corroded away that leaves 1/4 '', pits can go deep and leave you with the possibility of numerous pinholes. Steel can be corroded worse on the inside than the outside, have you looked there? To be limited on hauling out to certain places that charge a massive amount of money is a decided disadvantage. Have you looked around at other houseboats so you have an idea of what they are worth? Sam |
| oh give tar a big miss, cant be overcoated with anything else 235 is a good one, you can paint it is one as I explained, and it is as hard as rocks, to age coat it, you will need to use 201, but then you should neevr need to paint it, as far as it goes, if the owner is willing: get a sharp pick and go along and belt the thing here and there, IF the metal is dozey it,ll either dent it or go right through, this is how you survey a ship WITHOUT ultrasound |
| These pontoons do not have ready access to the interior bulkheaded compartments. One of the compartments did have an access plate, but it required removing a deck access panel in the middle of the owner's living area and then removing some 1" bolts with limited wrench clearance. The owner wasn't interested in having me do that. The owner is of the opinion there is no problem with the pontoons, and that I should just address any concerns I have about the pontoons by having them filled with foam. One compartment that was accessable was one containing the non-working diesel engine. There did not appear to be significant corrosion in the interior of that compartment. When I had the diver inspection, he went all over with a hammer and chisel, he reported everything sounded very good. I don't know how to compare this to other boats. I have looked at some other houseboats and cruisers, but I haven't seen anything like this, with all-steel construction and set up like a house with almost 2000 square feet of deck area, wired for 100 AMP power, 1000 gallon holding tanks, inboard wastewater pump, etc. FYI, The seller agreed to slightly less than their $50,000 asking price, conditional to my being able to obtain a satisfactory bid for lifting, blasting and painting. I haven't decided yet if $23K is satisfactory. If the beam were just 18" (.5m) narrower, I would have several other options for having the work done. If the engine was working, there a couple of other shipyards I could take it within 30-50 miles, but this is still a small-dollar job to them and I have been advised they are unlikely to be any more accomodating. So, if I get this hauled out, I want to do everything possible to make sure that I don't have to go through this again for a very long time. Looking at the manufacturer's info for Devoe Bar-Rust 235, this sounds like the verbal description of the paint I received a bid for. I have several more questions. A coat of 0.012" (300 micron) is about 50% more than the manufacturer's recomendation. Is a painter likly to consider this multiple coats? What is age coating? Is the moisture resistance of the High Build epoxy comparable to that of the coal tar? This may be a dumb question, what is wrong with a tar coating that cannot be overcoated? Is it impossible to build a tar coating up to 0.012"? Even if the engine were ever to be rebuilt, the boat would seldom ever go out, is there a need for an antifouling coating? Again, thank you all for your time and opinions, Sam |
| first no, you dont need antifoul as long as your wife is prepared to get over the side and scrub once in awhile Age coating is when you have to paint again , even after 6 months you need a paint that will BITE into the 235 or whatever was there yes you maybe right about the thickness, I was thinking measured wet(it then dries thinner) Seems so much money to paint, a commcercial; rig can blast a 4x12 foot plate in 10 mins, but I dont obviously no abt your prices in your part of the world if I member right the zinc is 302, but 201 is a lot cheaper will do ok look you are in the drivers seat, offer him 35 its a tricky deal buying a watercraft, What the diver said , seems like it's sound enough, I,m not there so I can't help much ) |
| 48' steel houseboat repair | spindoctor03 | Metal Boat Building | 2 | 05-04-2007 09:36 AM |
| houseboat | magjulmar | Open Discussion: All Things Boats & Boating | 5 | 01-11-2007 06:21 PM |
| Steel hull repair | Jason Crum | Metal Boat Building | 8 | 07-29-2006 01:34 PM |
| Lord Nelson 49' Trawler(tug Design) | LANDYACHT | Powerboats | 0 | 03-12-2005 05:56 PM |
| steel hull repair | minstrel | Metal Boat Building | 4 | 09-03-2004 01:46 AM |
