Old 05-03-2007, 11:37 PM
spindoctor03 spindoctor03 is offline
48' steel houseboat repair
I need some help on how to put a new bottom on my boat. It has the original hull but it has several holes and I believe it needs a new hull completely. Can you just weld a new steel plates to the existing hull using thinner metal to seal it or what is the best way to go about this. I do not believe that it is patchable.
Old 05-04-2007, 12:12 AM
Bergalia's Avatar
Bergalia Bergalia is offline
Rep: 254 Posts: 2,517
Hi Spindoctor....any chance of pictures to give a better idea of the problem. Patching may be possible if - and only if you have good sound material to support the weld. Wander around with a hammer and give a few 'raps' to see how much rust you can loosen - or how many new holes appear.
Old 05-04-2007, 09:36 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 253 Posts: 1,066
Like Berg said, pictures would be a big help.
She could be easily repaired, ready for the boneyard, or any condition in between. Get down in the bilges & have a good look around. If you've got damage on the exterior you most likely have some problems interior wise also.
Good luck & welcome.
TGoz
Steel hull repair Jason Crum Metal Boat Building 8 07-29-2006 01:34 PM
48' Viking Yachts Sportfisherman jaygee Boat Design 2 03-07-2005 09:07 AM
Restoring 48' Steel Motorsailer daveschile Motorsailers 3 01-19-2005 05:39 PM
GLOSS design - 48' Open glossdesign Boat Design 2 10-15-2004 08:01 AM
steel hull repair minstrel Metal Boat Building 4 09-03-2004 01:46 AM
