Old 09-21-2010, 10:46 PM
pcfithian pcfithian is offline
Rep: 15 Posts: 20
XPS/Luan Sandwich for Deck
I am about to install the decking on a Tolman Jumbo I am building and think a sandwich construction of 1" XPS Foam (Pactiv Greenguard) bonded with epoxy to skins of 1/8" exterior luan would make a very strong and light deck. This has often been used by others for cabin side and roof panels.
Once installed, the top surface would be glassed with 10 oz cloth and then finished with a non-skid like Durabak.
See attached for some calculations I've found on this site, but I am unsure of how much deflection I would get across the 30" span between the stringers.
Help and advice are greatly appreciated!
XPS/Luan Sandwich for Deck-painted-jumbo.jpg  XPS/Luan Sandwich for Deck-foam-sandwich-calculations-p1.jpg
Old 09-22-2010, 10:39 AM
Rep: 1493 Posts: 7,447
I have made several hard tops like that. They were used for towers on which the helmsmand would stand on. You need to fill the edges. The easiest way is to chip the foam back about an inch and fill with thickened epoxy.
Old 09-22-2010, 11:03 AM
Rep: 15 Posts: 20
Good advice on filling the edges, I had planned to do that. The only exposed edge will be at the rear. The other edges will but up against the hull sides and be glued to it.
How far between supports could this span and still deflect less than 1/8"?
Old 09-22-2010, 11:15 AM
You only need to support a 4X8 panel in the middle. I assume you mean with one person standing on it.
Old 09-22-2010, 01:19 PM
Rep: 15 Posts: 20
Thanks for the advice, Gonzo. But maybe the attached sketch will make it clear what I would like to do.
My question is, can I expect the XPS foam core with the 1/8" luan skins to be rigid enough to span the 30" between the stringers? It will need to support a person standing in the middle between the stringers.
XPS/Luan Sandwich for Deck-deck-cross-section-sketch.jpg
Old 09-22-2010, 01:28 PM
srimes srimes is offline
Rep: 186 Posts: 226
Don't you expect more than 1 person in the cockpit?
Old 09-22-2010, 01:41 PM
We used the panels supported only on the edges with no problem. That should work.
Old 09-27-2010, 06:04 AM
Rep: 15 Posts: 20
I was able to complete the equations and here's how it worked out. This type of panel is incredibly stiff!
XPS/Luan Sandwich for Deck-foam-sandwich-calculations.jpg
Old 09-27-2010, 09:23 AM
Rep: 186 Posts: 226
Nice. But what's the stress? Won't these types of panels fail before excess deflection?
Old 09-30-2010, 07:46 AM
Rep: 15 Posts: 20
I've decided against using a foam sandwich and will be using 3/4" ply instead. The weight savings don't justify the extra work and drawbacks of a foam sandwich. Here's what the deck cross section will look like:
Old 10-13-2010, 05:43 PM
Rep: 15 Posts: 20
I've modified my design to use XPS foam for floation under the deck. Here's what it will look like:
Extruded Polystyrene (XPS) gabdab Fiberglass and Composite Boat Building 78 12-30-2011 08:30 AM
xps foam boat pradenk Materials 2 07-09-2010 12:51 AM
Luan reliability? jalexfolds Boat Design 55 04-04-2009 11:50 AM
5 ply luan lprimina Materials 5 02-02-2005 04:01 PM
Go with the Luan or is there a better alternative? darr Wooden Boat Building and Restoration 4 01-05-2005 02:50 PM
