Old 06-29-2010, 12:36 AM
pradenk's Avatar
pradenk pradenk is offline
Rep: 10 Posts: 7
xps foam boat
i'm building an xps foam boat, i made the boat and ran the electrical. the lights might need to be moved but for now ill wait to see if the lights will be submerged. they (the lights) are not fixed and will not be in this place when the boat hits the water. anyways i need to coat it and do not want to glass it, does anyone know of a liquid plastic, rubber, or polyurea that wont eat the foam. any suggestions will be appreciated. [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 06-29-2010, 01:06 AM
J3 J3 is offline
Rep: 16 Posts: 60
Are you going to hot knife or shave the shape so it will ease through the water a bit easier?
Old 07-09-2010, 12:51 AM
pradenk's Avatar
Rep: 10 Posts: 7
sorry for no getting back sooner, i wanted to but i think im going to leave it cause its only a creeper boat made to get into places other boats cant. about 6 to 8 in. of water. it will only have a trolly motor and oars. im not into glassing it cause if its not done right can gived you problems. i found something called styrospray and got samples, it adheres to foam better than i thought and is hard like glass but dont know how eaqual it is to glass without doing test. have not used it and dont know if used as a submersible coat would it stand up to water and uv. but it is a strong coat for a foam and if anyone used this product before as an outdoor coating for a project did it stand up well against water and uv.
Extruded Polystyrene (XPS) gabdab Fiberglass and Composite Boat Building 78 12-30-2011 08:30 AM
foam core for small boat Ron Skelly Boat Design 1 12-10-2009 01:23 AM
Foam flotation for aluminum boat kdolan Metal Boat Building 6 02-06-2005 06:46 PM
Foam Block To Bass Boat... can this be done? Curious Fiberglass and Composite Boat Building 10 12-11-2004 06:21 PM
One-off 16 ft. flats boat - using foam core JR-Shine Boatbuilding 0 05-07-2004 08:40 AM
