Old 05-19-2008, 09:07 AM
Canivour Canivour is offline
Rep: 10 Posts: 10
Would You Use Hollow Stringers?
I am replacing the deck and stringers of my recently aquired 1970 glastron v163 (16'). Most of the wood of the stringers is nothing but soggy sponge. I was curious if I could just remove the wood from the stringers, leaving what glass is already there, then put foam (or even just leave it hollow) in replace of the wood and re-glass the stringers.
I am son of a wood worker so I have access to a shop and tools with plenty of woodworking experience, yet I believe this done right could be stronger, lighter, and more easily done than replacing the wood with new wood.
Would you do it and if so how many layers on the stringers would be sufficient?
Old 05-19-2008, 09:35 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
Without any calculations and just for myself I'd leave them hollow, adding a bit of unidirectional S-glass (first in 0 deg. direction of the stringers and the thinnest +-45 I'd happen to have on top going wider on the sides) total amount being at least the same weight as the wood in the stringer had been or if some of the original grp is removed adding that weight too.
Not very pro solution but..
Old 05-19-2008, 10:20 PM
Rep: 2891 Posts: 8,798
I wouldn't make you stringers hollow. Yes, the laminate is the bulk of the structure, but the wood acted as a core, preventing distortion of the separated areas of laminate, keeping them from collapsing or buckling under load, which would be an easy thing to do without a core.
Cut the stringers free, replace with similar dimension wood or other suitable core material, then re-tab the stringers back to the hull shell. Of course you'll want to insure good adhesive contact with the new core and any old or new laminate you install.
Old 05-20-2008, 01:46 PM
Rep: 10 Posts: 10
yeah, im in the proccess of cuting right now...
Old 05-20-2008, 03:16 PM
If you're neat about cutting them out, you can reuse the tabbing and stringer shells. This assumes the new stringers will be pretty much the same dimensions as the old of course. This saves a fair amount of work and laminate bulking.
stringers arikalucky13 Materials 2 08-19-2006 11:46 AM
Solid Strakes or Leave Hollow? IHTFP Fiberglass and Composite Boat Building 1 04-17-2006 08:49 AM
stringers Boat Craze Materials 2 03-17-2006 11:57 AM
Tear drop shape hollow wooden mast - info needed please tschienque Wooden Boat Building and Restoration 3 09-20-2005 07:22 AM
hollow entry? rickc Boat Design 15 10-28-2003 06:35 PM
