Old 08-13-2010, 09:50 AM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Wood / Laminate recomendations
Hello, I am in the process of rebuilding my galley and I was thinking of using 1/4 ply and glassing it, with 1/2 for the top counter.
Can you recommend a laminate type/weight to use?
I will be using epoxy.
There wont be an ice box going back in so the structure wont need to support as much weight as before there will just be a sink, a hole for a stove to Gimbel in and the back part will be for storage.
Is 1/4 plywood sufficient for this?
Wood / Laminate recomendations-dscn7218.jpg  Wood / Laminate recomendations-dscn7225.jpg  Wood / Laminate recomendations-dscn7245.jpg
Old 08-13-2010, 03:59 PM
apex1
1/4 is about 6mm right?
When glassed it will be sufficient.
Regards
Richard
Old 08-13-2010, 04:11 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Yes 6mm, I was thinking a couple layers of 10oz cloth but am unsure of the weight or buildup I need.
The glass I removed was 6mm or 1/4" thick and the cored top was around 3 mm glass per side over 12mm plywood.
I dont think I need 3mm of glass per side of 6mm plywood though...
Old 08-13-2010, 04:29 PM
apex1
No, 3mm would be too much, I would go for some 300gsm (gram mē) per side. 240gsm fabric 60gsm mat.
The weight is almost always twice the weight of the glass + 10% for handlayup.
Hope that helps!
Richard
Old 08-14-2010, 02:03 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
So one layer of mat and a layer of Fabric.
what is the best fabric to use 0 / 90? and maybe +-45 for the tabings?
I would use MERANTI BS 6566 6MM 5 PLY sound good?
What is the difference between the BS 1088 and 6566?
Old 08-14-2010, 03:47 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,055
For interior, to be glassed with epoxy and non structural almost any decent ply..
+-45 biax IMO ..
Old 08-14-2010, 04:24 PM
apex1
Quality and price
Is ok, cover the inside with neat Epoxy (which you need anyway to balance the "pull" of the outer layer!)
As Teddy said, + - 45°
Regards
Richard
Old 08-14-2010, 04:54 PM
CSX's Avatar
CSX CSX is offline
Rep: 10 Posts: 15
Great,
Thank you
Old 08-14-2010, 06:52 PM
apex1
Welcome, and have a great day (or some) on the water...........
ahh, and the mat is on the OUTSIDE!......................
me
Help w/ engine recomendations Jping102 Diesel Engines 1 07-26-2010 05:05 AM
icemaker for my boat any.. recomendations oinkjackson Open Discussion: All Things Boats & Boating 2 08-23-2007 07:15 AM
Recomendations for new transom material? 85 starcraft Metal Boat Building 28 08-09-2007 11:08 PM
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 08:32 PM
Program Recomendations Goonda Education 1 02-10-2005 07:52 PM
