Old 12-06-2004, 12:42 PM
drs3317 drs3317 is offline
Rep: 10 Posts: 47
wood for interior finishing
Can hardwood veneer plywood;cherry,oak,walnut,ect., be used inside a boat for wall panels and cabinets without worry of delamination form the humidity? Would it be necessary to epoxy it first to seal it or would varnish or polyurethane be sufficient? I would like to change my interior from all those vinyl covered side panels and maybe even use 1/4" oak veneer for the headliner.
Old 12-06-2004, 10:16 PM
glassman glassman is offline
Rep: 15 Posts: 36
yes you can but use a good co. not your home center because you will need 4-8 and 8-4 so you dont have alot of seams and about coating with epoxy not need a good varnish is all you need
Old 12-07-2004, 02:00 AM
Rep: 2891 Posts: 8,796
What Glasman said about not using varnish if using epoxy is foolish. Epoxy has no UV protection and will break down rather quickly if the sun light from a port or hatch falls on it. In just a few months the shine will be noticeably less and the color will be darker, in a few more months the epoxy will be very dark and starting to break down, where the wood will begin to show. It's a fast down hill slide from there. The rest of Glassman's comments I didn't really understand, and seeing as I probably just pissed him off I'll leave it alone.
Epoxy isn't the cure all a lot of folks would have you believe. It's expensive, toxic, messy and can be difficult to work with in some conditions. Delamination in solid wood veneers is possible when wet/dry cycling occurs between the lumber and adhesive used to bond it to the substrate. If the substrate (surface it's being bonded to) is stable or reasonably so, like a fiberglass bulkhead, then only the wood needs be sealed and a water proof adhesive used. There are several water proof adhesives available, most much less costly then epoxy. If the substrate is less stable like solid lumber or to a lesser degree plywood, then this surface must be sealed as well.
I like varnish to seal wood. Polys are nice, develop a great shine, last a long time, but if let go to long or abused, are all but imposable to repair without stripping. If varnish is dinged, the ding can be feathered and more varnish "flowed" into the area. If it has been let go for too long, it can be abated (sanded) and fresh coats applied to restore the finish. This isn't the case with poly's, they're just too hard. A ding requires removal and reapplication as does a poly finish not kept up.
About using 1/4" oak veneer for the headliner. If the area is reasonably small, then go for it, but large areas may have the added result of a lot of weight in a position where you may not want it. Typically you'll find red oak at the local home centers and it has very poor rot resistance qualities about it, though in veneers or the thin stock you've got in mind, it may do okay if well sealed. This is a place I would use epoxy (CPES). The 1/4" thick strips of red oak would suck up to near saturation and be pretty rot free for quite along time.
Personally, I use resorcinol (completely water proof) or plastic resin adhesive (only water resistant, but good inside a boat) to bond the veneer (both usually available at the local hardware store) and then varnish to suit (also available at the local Ace) Use real solid wood veneers or use exterior or marine grade plywood (1/8" is fine for furniture or liner skins) The thin plywood will be a special order from Lowes/Depot if they can get it as will the solid wood veneer. You may have better luck at a custom cabinet shop getting lumber or ply. Mail order supply houses are another option.
Old 12-07-2004, 06:02 AM
Rep: 700 Posts: 3,208
Epoxy is a far better Glue than surface finish.
FAST FRED
Old 12-08-2004, 12:08 PM
NOTIME
If You Read What I Said I Said Varnish Is The Way
Old 12-08-2004, 10:42 PM
Rep: 15 Posts: 36
think before you speak
if PAR. read what i said then he may have been write, but i had said epoxy is nogt need inside and varnish is all . i dont like someone to bad mouth me when they cant read what was posted
Old 12-09-2004, 12:15 AM
Rep: 1397 Posts: 7,215
Well glassman, if you took a bit more time checking your grammar there would be less confusion. It is difficult to tell what is it you're saying.
30' cypress cabin cruiser wade Wooden Boat Building and Restoration 28 04-24-2006 05:36 PM
best low tox wood preservative lofting4fun Wooden Boat Building and Restoration 3 08-27-2005 03:33 PM
Use of wood as core in polyester jfblouin Materials 24 02-20-2005 09:38 AM
Looking for wood species in Asia for strip planking Daren Boat Design 33 12-09-2004 02:46 PM
Wood sealing help needed RobinFLINT Wooden Boat Building and Restoration 4 08-31-2004 09:16 AM
