Old 07-16-2006, 11:10 AM
bazza bazza is offline
Rep: 10 Posts: 25
window plastic
about a year ago I replaced all the window and port plastic on my boat. I contacted industrial plastics and sought there recomendations.they recomended 6mm cast acrylic for windows and 8mm for hatches. it is in a fairly dark tint. in the past silicon and black 4200 and mastic has been used as sealants. the acrylic is screwed to the outside of the hull. 5/16 holes with 1/4 screws. the sealants have allways leaked and never held to the plastic. this time i used sikaflex 295uv with primer. boy does this stuff stick. well the seal remains intact but one by one the windows are cracking from top to bottom mostly starting at screw holes but some not,due to different expansion rates to the glass/foam they are sealed to. when cold there is about a 1mm crack. the crack closes when hot. industrial plastics say this is the product used worldwide as an industry standard. I figure that i replaced the acrylic in bright carribean sun and the plastic was expanded when the sealant set, maybe thats the problem. I asked about polycarbonate. they could not give me an answer. my thoughts are it seems softer so it may not be as brittle. also what about thicker. 10mm is the next size in polycarbonate. what do you think.
bazza
Old 07-16-2006, 10:30 PM
georgelewisray's Avatar
georgelewisray georgelewisray is offline
Rep: 10 Posts: 8
Plastic needs to float in it's mounting..
If the plastic was fitted so the fastenings were sort of snug in the holes then when the plastic MOVES it sets up a lot of strain against the fastenings and the cracks usually start in the fastening holes.
The holes need to be a good bit bigger than the fastening and a washer on top under the fastening head will hold the plastic while letting it move about as it expands/contracts.
Old 07-17-2006, 08:08 AM
Rep: 10 Posts: 25
all holes were drilled oversize and have clearance to screws with washers. still cracked. some cracks are not even at screw holes.
bazza
Old 07-17-2006, 02:39 PM
Rep: 10 Posts: 8
Secured to tightly?
I have ALWAYS heard that float was critical. Even if the fastening holes were oversize, if the plastic were pulled down tight on a "THIN" bed of glue like bedding compound it could prevent expansion/contraction and promote the stresses that would cause cracks to develop.
pictures?
sliding window handle erie1 Powerboats 0 03-02-2005 07:28 AM
Recycled Plastic/Plastic Lumber Hulls for Pleasure Boats? Keith King Boat Design 8 09-29-2004 02:17 PM
How thick for window glass Willallison Sailboats 16 08-24-2004 03:02 PM
Window Design for Custom Steel Yacht pkoken Boat Design 17 05-05-2004 08:53 PM
Methacrylate window sticked at fiberglass frame mikels Fiberglass and Composite Boat Building 7 02-23-2004 03:22 AM
