Old 08-01-2011, 05:20 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
Where can I get GOOD INFUSION EPOXY? :)
Like the cheap epoxy thread, but I'm looking for suggestions on your favorite infusion epoxy.
What infusion epoxy can I get that has my dream characteristics, or close to it?
1) No Post Curing Required
2) 2:1 or other simple mix ratio
3) Flows like water
4) Plenty of open time
Any suggestions on the best infusion epoxy out there?
Kurt Hughes was right about this place.
Old 08-01-2011, 05:47 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
I've used this stuff I found on e-Bay.
http://cgi.ebay.com/EPOXY-RESIN-VACU...item483a5f3761
it's ok.
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 08-02-2011, 01:27 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
From the Ebay ad:
MAY REQUIRE HEAT CURING TO ACHIEVE ADEQUATE DEGREE OF CURE FOR HANDLING
In other words: Without heat, it cures into a very brittle state.
Non-post-cure long open time epoxy is something that is about non-possible to formulate. (at least, if you want a decent Tg)
I suggest you develop something to easily postcure. Use the sun, and your imagination.
Old 08-02-2011, 04:59 PM
Originally Posted by Herman View Post
From the Ebay ad:
Thanks, guys.
Herman, I figured you would know the answer and you did. There is no such thing as long open time, no post cure epoxy... I was thinking this, but needed to confirm it. I suppose I'll have to rent heaters and blast the whole boat next summer at one time.
Will probably go with MAS.
Old 08-02-2011, 11:11 PM
Deering Deering is offline
Rep: 14 Posts: 219
How about getting the slowest curing hardener you can find, then heat the mix up to maybe 120 deg F right before infusing so it runs like water. Depending on the piece you're infusing, maybe you can get it in place before the mix kicks? I've used that trick in other applications, but never tried it infusing.
Old 08-05-2011, 09:18 AM
pauloman pauloman is offline
Rep: 65 Posts: 55
folks I know use Basic No Blush marine epoxy with the slow summer curing agent. Which it was a bit thinner, but seems to work from what I've heard. $96 for 1.5 gallon kits.
Old 08-05-2011, 09:22 AM
That definitely wouldn't work. I need a 2 hour open time or so. It's already 103F right now where I'm infusing, so I don't think heating epoxy is an issue here.
Old 08-05-2011, 12:49 PM
Herman's Avatar
Resininfusion.info
There is a couple of things that are important:
-Tg (for exterior use you want a high Tg epoxy)
-viscosity at working temperature
-geltime at working temperature. Preferably 2 figures: 100 gram batch and 1 kg batch. (sorry, I am not handy in imperial)
Old 08-05-2011, 01:43 PM
Yes! I found out about the larger batch times today when I tried an infusion without the correct materials.
I tried infusing a small rudder part about the size of a boomerang.
I used cheap plastic from the hardware store. I used a sticky tape from the hardware store that actually worked well, though it's more expensive than real bag tape.
I had some holes in the bag (should have known when it didn't hold a good vacuum, but I got impatient and wanted to try it). It is very exciting.
Anyway, I mixed up my epoxy (standard hand laminating epoxy) and started the infusion. As soon as the epoxy starting making its way up the boomerang size part, I saw a stream of bubbles going through as well. I tried to close it off, but the leak could not be found before the epoxy kicked off in the supply bucket (small cup, actually).
So, the first infusion is a failure, due to lack of patience and lack of proper materials.
I think I must order my real materials before I can "practice" any more.
Thank you, for that input Herman. I will seek those numbers. I do know that the MAS infusion epoxy I was looking at using has a better Tg than even the hand laminating epoxy from System Three I had been using all along. However, it does require a post cure.
Old 08-05-2011, 06:06 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
It's a good thing to make mistakes on small & practice parts- good lessons in that, my first infusions where with the lab tech at FGI, who I think deliberatly set some up for that purpose. Regards from Jeff.
Old 08-05-2011, 07:31 PM
Sand crab Sand crab is online now
Rep: 23 Posts: 66
Cool it
My buddy keeps the stuff in the fridge. He claims it gives him about 25 to 50% more working time. Depending on well.... everything. BOB
Old 08-07-2011, 02:49 PM
Couple pictures of successful infusion using 100% Home Depot junk. It's just fine for small parts, such as this rudder section:
Where can I get GOOD INFUSION EPOXY?  :)-imag0404.jpg  Where can I get GOOD INFUSION EPOXY?  :)-imag0405.jpg
WTB: used books, articles, videos on resin infusion / vacuum infusion Ern.Bieman Marketplace 0 04-28-2011 09:41 AM
(Prime 20 LV infusion Epoxy) foaming under vacuum otseg Materials 25 06-21-2010 01:06 PM
Good finish for Interlux Epoxy 3000/3001 primer/barrier coat? stimulous check Fiberglass and Composite Boat Building 4 07-18-2009 01:34 PM
Are there any good cheap epoxy resins? Texas-Tri Materials 26 08-01-2008 02:11 PM
good price epoxy for molds Vanbokklen Materials 0 02-07-2005 07:18 PM
