Old 08-05-2011, 09:34 AM
pauloman pauloman is offline
Rep: 65 Posts: 55
be sure you are buying formulated marine epoxies and not just the raw resin stuff purchased in drums for the giant chemical raw material manufacturers. The big good guys start with the raw materials and add to them for desired properties.
The super cheap guys don't.
You want to use a formulated product and one offered by a re-packager.
Also consider issues like blushing (bad) or non blushing (good - cost more)
another trick - email the vendor about anything and see if they reply back. If they won't bother with you before you buy, they certainly will not after you buy.
Old 08-17-2011, 11:37 AM
Jeremy Clarkson Jeremy Clarkson is offline
Rep: 19 Posts: 25
Yes, it needs to be carbon wich I have been getting for a great price on ebay. But the epoxy is killing me to buy
Old 08-17-2011, 12:06 PM
Rep: 65 Posts: 55
see www.epoxyproducts.com/mepoxies.html
for info on how to compare/evaluate different marine epoxies.
Old 08-17-2011, 04:23 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
pauloman, Great link.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 08-17-2011, 04:58 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
These folks have good prices and won a test over the big boys. I'll try to find it abd post it. http://www.raka.com/
Here are the test results http://www.oneoceankayaks.com/Epoxresl.htm
Old 08-18-2011, 07:35 PM
Rep: 3125 Posts: 9,399
That's no test Stan, more of a playing around sort of thing. Raka isn't bad, though a bit thin, which is good for some things, not so much for others.
Old 08-21-2011, 08:00 PM
skyking1 skyking1 is offline
Rep: 10 Posts: 30
system 3 epoxy is based in Auburn, but by far not the cheapest.
http://www.systemthree.com/store/pc/...urpose-c11.htm
Another local supply house is Fiberglass Supply up in Burlington.
http://host0140.csmhosting.com/iwwid...ducts?comp=FS1
If either were on your way to somewhere, you could save the shipping.
I have used system 3 silvertip for coating, and Resin Research for laminating and coating.
The Resin Research worked OK and compares favorably in price with anything out there, if you are in the neighborhood.
Old 08-21-2011, 10:35 PM
Again, if buying small quantities, then $60 a gallon is about the best you can do at retail.
Old 08-22-2011, 06:06 PM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
I don't know anything about the epoxy but I do about economic ordering quanities. Why don't you get with other builders who use the same or similar products and buy in quanity. Have it shipped to one place or person who will break down the order and send it out to all parties, maybe that guy gets a little better price. You're goin to be paying shipping if it is not available locally anyway. You might also get some dealers to break out shipping and still give you a discount for group buys.
Cheap fiberglass and epoxy or alternative Elias_Fleishman Wooden Boat Building and Restoration 15 02-25-2011 08:54 PM
Cheap epoxy, any reason why it won't work for laminating? LundieF Fiberglass and Composite Boat Building 11 12-15-2010 10:45 AM
System Three Epoxy Resin and Hardener #3 FOR SALE CHEAP CatBuilder Marketplace 3 09-29-2010 12:28 PM
Cheap to run, cheap to build electro plywood cruiser ? ASM Boat Design 72 08-08-2008 09:13 AM
Are there any good cheap epoxy resins? Texas-Tri Materials 26 08-01-2008 02:11 PM
