Old 08-24-2010, 08:05 PM
Mark Emaus Mark Emaus is offline
Rep: 20 Posts: 86
where can I find hydraulic fittings
Does anyone know of a wholesale company that will sell welded hyd. fittings for steel or aluminum tubing?
thanks
Mark
Old 08-28-2010, 11:45 PM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
Grainger http://www.grainger.com/Grainger/wwg...0&sst=subsetor McMaster-Carr http://www.mcmaster.com/#hydraulic-fittings/=8lxkd8have regular fittings. Weld them yourself or have a welding shop do it, if they're qualified.
Old 08-30-2010, 04:30 PM
Rep: 20 Posts: 86
I was hoping to have pre made fittings that were welded. Again does anyone know where I might get welded fittings?
thanks
Mark
Old 08-30-2010, 04:55 PM
wardd wardd is offline
Rep: 443 Posts: 925
why do they have to be welded?
liberty ships were beautiful
Old 08-30-2010, 09:53 PM
Fittings connect things. Welded ones are already welded to something. Maybe you want weldable fittings? What kind, what size, how much pressure?
Old 09-16-2010, 08:07 PM
Rep: 20 Posts: 86
looking for 1 inch male JIC that can be welded to 1 .25 inch pipe to withstand 3000 psi
thanks
mark
Old 09-16-2010, 08:12 PM
Rep: 443 Posts: 925
thanks
mark
I'd use schedule 40 or 80 threaded pipe and fittings
or stainless high pressure tubing flared
3000 pounds is nothing to play with, a pin hole leak will slice and dice you
Through hull fittings 42 below Metal Boat Building 65 03-23-2011 11:47 PM
fittings for Seastar hydraulic steering naturewaterboy OnBoard Electronics & Controls 0 09-12-2009 09:57 PM
Deck fittings Mike Field Marketplace 0 05-07-2009 07:25 PM
plastic fittings. Frosty Powerboats 12 04-05-2007 10:59 PM
thru-hull fittings Sailboats 3 09-14-2002 09:33 AM
