Old 01-20-2011, 02:36 PM
Boston's Avatar
Boston Boston is online now
Rep: 1457 Posts: 3,355
Whats this rumor about epoxy might not be so great at encapsulation after all
I keep catching hints that epoxy might not be the end all beat all for encapsulation after all
whats up with that
some new studies actually get released sayin something about water infiltration or whats the deal
too many builders cheeping out on not enough coats and woods rotting
whats the skinny cause I actually do plan on building something eventually.
I am skeptical of the deniers diatribe
Old 01-20-2011, 03:01 PM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
This is your most likely answer.
Kurt Hughes was right about this place.
Old 01-20-2011, 03:06 PM
Rep: 3125 Posts: 9,399
What "new studies"? The only epoxy studies I've seen in this regard, are those about penetrating epoxies, which aren't waterproof and this has been accepted for many years, though there are many "hold outs" that also still believe the world is flat too, like Larry Pardey who thinks epoxy is just a "fad".
Old 01-20-2011, 03:13 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
I've never heard of this. Encapsulation means 3 coats on all surfaces, miss nothing, and do not thin the epoxy. Ive been on the Glen-L forum and this one for years and have never heard anyone say on wood boats it is not the thing to do. I have heard about water infiltration but that is because someone did not cover all areas or there were punctures. I'm assuming all bottoms were fiberglassed also and most had sides and tops fiberglassed using a known and proven supplier and product. You do not need 3 coats under fiberglass because the wet-out will provide more than enough epoxy for a total seal. On mine I intend to get into the hull with a big brush and a gallon of slow hardiner epoxy and coat everything heavy for 3 coats. the 2nd and 3rd applied when the provious coat is still tacky.
I don't intend be be real neat about it but it will be thorough........
Old 01-20-2011, 03:19 PM
Boston's Avatar
I suppose I should have worded it
are some new studies
I"m just curious cause every once in a while I hear something negative about epoxy encapsulation and just thought I'd ask
Old 01-20-2011, 03:20 PM
mark775
Okay, Bos, We've got a lot (hundreds) of these Renn Tolman skiffs here. (Plywood with epoxy barrier). They never get water in the plywood accept where it is damaged and some of them have been in the water for decades. To me, the problem is that they do get damaged and water gets in the plywood. I would use Shelman plywood with the fungicidal glue and not fret for them but I just don't see a problem otherwise.
Old 01-20-2011, 03:50 PM
Just do not use it for internal lubrication
Old 01-20-2011, 05:15 PM
. . . Oh crap, I'm screwed . . .
Old 01-20-2011, 05:48 PM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
whats up with that
to many builders cheeping out on not enough coats and woods rotting
Really Boston, is this a serious post?
You have been around here long enough to see lots of questions just like this one. The fact is that epoxy is not 100% moisture impermeable and very few materials are, other than metal. So what. The moisture that does make its way through an epoxy barrier does not mean that the boat will rot and sink in 3 months. Most all fiberglass boats that you see in marinas have a lot of moisture that has permeated through the hull and caused a loss of strength but they don't rot and sink either. I and many here who regularly use epoxy as a barrier coat on wood boats have a long history of such practice and know that, properly applied, epoxy is a superior coating material.
Of course, there are always naysayers around and they jump out of the dark bushes to pounce on such "studies" at every opportunity. The sky is not falling. You can go with those who know or be misled by rumors. I too have seen rot take over boats that were "encapsulated" in epoxy but, in every case, inadequate or faulty use of the product was evident. It ain't perfect and needs proper use to gain the most benefit but, until something better comes along, most of us will gladly take it for what it offers to the longevity of our boats right now.
Tom Lathrop
Old 01-20-2011, 06:00 PM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Just follow sound practice- epoxy encapsulating a SPF 2x4 will not turn it into a boat building material.
Old 01-20-2011, 08:25 PM
Originally Posted by bntii View Post
. . . epoxy encapsulating a SPF 2x4 will not turn it into a boat building material.
Yes, it will . . .
Old 01-20-2011, 09:07 PM
bntii's Avatar
Yeah- I have to agree though I generally don't pick up my materials at the local home depot..
Old 01-20-2011, 10:40 PM
It may have been more helpful to have just stated that instead, don't you think?
Old 01-20-2011, 11:07 PM
Boston's Avatar
well I guess that answers that
lots of pretty spirited defense of epoxy
just checking
reason for just checking might be that the industry doesn't disclose longevity studies concerning epoxy, instead they seem to have this canned answer of "well we have boats that have survived almost 50 years". Which leads me to wonder about the ones that didn't. Anyway after studying my options I'm kinda stuck with epoxy ( no pun intended ) as far as I can see. Best to keep up on the latest though and that means asking dumb questions from time to time. Nice to know the peanut gallery is still on my team.
Old 01-20-2011, 11:26 PM
There are long term trials and environmental impact accelerated testing to look at, if you have specific questions Dan.
Delftship? Whats up Ike Software 7 12-19-2010 04:09 AM
Epoxy Encapsulation and Varnish MastMonkey Wooden Boat Building and Restoration 9 08-27-2010 10:32 AM
Great sail, great gale, a little carnage and lessons learned CharlieCobra Open Discussion: All Things Boats & Boating 9 11-20-2007 12:49 PM
Great site here with great stuff... Gbenz Open Discussion: All Things Boats & Boating 7 07-18-2006 10:07 PM
Whats going on people Littlebearcanoe Boat Design 2 09-07-2005 07:06 PM
