Old 12-08-2010, 01:09 PM
GlenM GlenM is offline
Rep: 10 Posts: 3
What Type Steel
I bought a 1981 Goderich 37 that was mfg. by Huromic Boat Works in Goderich Ontario. It is a Brewer design with a round chine. The company has since shut down.
The metal on this boat is around 3/16 and is very hard to work with. Small dents received from Hurricane Ike were straightened with many blows of a 2 lb sledge hammer. The previous owner has no idea what type steel it is. The boat yard seems to think its Cor-Ten. They could not believe it was so hard to bend. I emailed Ted Brewer and he said he gave the company the option of corten or A-36.
I am leaning to the corten
I need to cut out some of the steel in the sides of the cockpit storage holes, and weld in some patch plates. Would it hurt to weld corten to mild steel.
Any suggestions appreciated.
Thanks
Glen
Old 12-10-2010, 07:11 AM
apex1
Any suggestions appreciated.Thanks
Glen
Hi Glen,
for me it is not clear what you are going to do.
Are you thinking about welding the patches in mild steel or are you going to apply cor ten?
If it bends as hard as you told us, it is most likely cor ten, you should replace it with cor ten then.
Regards
Richard
Old 12-10-2010, 12:11 PM
Rep: 10 Posts: 3
I have cut out the rusted area 6"x 18" and need to weld a piece of plate back in.
I need to know if I need to use cor-ten or A-36.
Old 12-10-2010, 02:03 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Originally Posted by apex1 View Post
Hi Glen,
Regards
Richard
Like Richard said. He would know.
Hoyt
whicht type of steel Lexluthor Metal Boat Building 7 09-05-2010 08:29 AM
what size guage steel for this type of hull? Steve32 Boat Design 7 02-05-2010 12:14 PM
new type of sailboat Ron Skelly Sailboats 4 11-20-2009 09:29 PM
Free of charge, Steel - polyurethane foam -Steel insulation sheets rossgiles Fiberglass and Composite Boat Building 0 03-18-2008 06:43 AM
best stern type urisvan Boat Design 27 04-24-2007 12:49 PM
