Old 05-08-2011, 12:32 PM
vaporvette's Avatar
vaporvette vaporvette is offline
Rep: 15 Posts: 29
what type of glass and paint do i need?
I am going to repair the bilge in my boat.This requires me to glass a piece of wood into place on the floor. I'm going to replace the piece of wood with holes in it with a piece that has some wide screening instead of the holes.
Are there different kinds of cloth and resin? I also plan to paint this area and need to know what paint would be good and chip resistant. Finally the wood, Should I just treat some plywood or do they sell something else.
Thanks.
Old 05-08-2011, 12:38 PM
Rep: 1493 Posts: 7,447
That looks like the typical polyester/fiberglass mat layup. You can use any water proof plywood. Cover all the exposed wood well and then coat with waxed gelcoat.
Old 05-08-2011, 12:48 PM
vaporvette's Avatar
Rep: 15 Posts: 29
I thought gelcoat was used for a smooth finish,like on the outer skin. Is it brushable,how should I prep it?
Old 05-08-2011, 02:44 PM
You can put it right over the fiberglass laminate. It is simply polyester resin with pigment and a load to make it thicker.
Old 05-08-2011, 03:10 PM
vaporvette's Avatar
Rep: 15 Posts: 29
Thanks gonzo,any specific brand gel coat you recommend? also,where do I get marine grade plywood or should I just treat regular wood with some type of sealer?
Steps to prep green glass for paint? shizlenut Fiberglass and Composite Boat Building 7 04-11-2011 05:50 PM
Painting my boat -- what type of paint? declan Boatbuilding 8 09-21-2010 11:33 PM
Paint type best to cover texured fibergalss deck and catwalks northrivergeek Boat Design 3 02-24-2009 12:41 AM
Repacing Stringers-Type of Glass? pairomedicsfish Fiberglass and Composite Boat Building 6 06-29-2006 10:10 AM
How to identify type of paint? edincedar Metal Boat Building 3 08-08-2005 01:26 PM
