| what is the most popular domestic hardwood (US) for cold molding so what is your most recommended domestic hardwood for cold molding ps please dont even remotely recommend Dougy firstly its not a hard wood and second Douglas fir is pure crap and having worked with the stuff in the housing industry for years its simply not even the remotest of considerations. I am interested in Domestic hardwoods in the US area and ones that have reasonable rot resistance and stability. The material must not have gluing issues, be rot resistant and readily available soon as I figure out how to do it Ill post a pole of the various wood available B
__________________ I am skeptical of the deniers diatribe |
| I suggest to don't use any hard wood for cold moulded. You will be on a bad pickle. You don't like fir, it's ok, use a light mahogany, like the okume, if you don't like import, use cedar, use what ever you want, but not hard wood for cold moulded. Daniel |
| Quarter-sawn yellow pine would be my first choice for a US wood. Hardwood? Hardwoods are heavy for their stiffness. The hull would normally have to be thinner, which would reduce stiffness. Therefore, any hull design would specify wood options. The designer would know what changes in species would do to hull weight. No designer involved? Fir is a damn good boat wood for a lot of reasons. Regardless of your experience, having spent many years in the building trades I can attest that fir is strong and relatively rot resistant. It is the wood of choice for decking covered porches tongue and groove style, has been for decades. It is not easy to plane by hand due to the grain being "rowed" or interlocking. However it would be a first-class choice for a domestic cold-molding wood. really, of all building methods, cold-molding is among the most amenable to wood choices for reasons other than rot-resistance. It is fully epoxy-encapsulated in and out. It most closely resembles plywood---- is in fact a kind of molded plywood. Rot would only happen if there were a breach due to impact. The physical damage would be simple to locate and repair, or if really extreme, call for being repaired long before rot could set in. Only extreme negligence would allow rot to develop. Compare this to a car body. The paint is like the epoxy encapsulation. Steel is used even though it rusts instantly in the presence of water. |
| well then we are right back to poplar which I have worked with extensively and has far better characteristics than pine and no worse rot resistance after all the rot resistant qualities of a wood are found in its heartwood and the percentage of sapwood in today's yellow pine also known as pitch pine is very high poplar is lighter, stronger, and far more readily available. It has been used successfully in the production of small marine craft by at least one famous builder and when encapsulated is just as likely to last just as long and without the inconsistencies of pine. basically after 30+ years of hands on working wood and after using pine for a majority of that time I can absolutely assure you of the inferiority of pine. Its use being mainly driven by its abundance and not by its quality
| Your choice of wood will depend also of the shape of the boat. Since one of the layer will be close to 90 degree from the keel, the bilge radius will tell you more that anything else. How's the drawing going by the way? Daniel |
| drawing is going fine now that I am able to draw again thanks for asking the old back seems to be feeling a bit better lately Ok I got curious about how the actual numbers stack up so I thought Ild dig em up from several sources and lay them out side by side, then compare them by weight and cost from wood a manual for its uses in wooden vessels ( US Navy ) weight ( specific gravity ) yellow pine .58, short leaf .51 hondo .45 poplar .40, red cedar .33 white cedar .32 fiber stress at proportional limit long leaf yellow pine 9,300 hondo 8,850 short leaf yellow pine 7,700 poplar 6,100 cedar 5,300 w cedar 4,900 modulus of both rupture and elasticity yellow pine 14,700 and 1,990 short leaf 12,800 and 1,760 hondo 11.140 and 1,430 poplar 9,200 and 1,500, cedar 7,700 and 1,120. w cedar 6,800 and 930 static bending stress to both proportional limit and maximum load yellow pine 2.44 and 11.8 short leaf 1.93 and 8.2 hondo ( data not available ) and 6.8 poplar 1.43 and 6.8 cedar 1.44 and 5.8 w cedar 1.46 and 4.1 impact bending at proportional limit in lb/sq inch and impact height to failure yellow pine 15,400 and 34 short leaf 13,600 and 33 hondo ( data not available ) and 22 poplar 13,500 and 20 cedar 8,600 and 17 w cedar 7,600 and 13 shear parallel to grain and hardness parallel to grain yellow pine 1,500 and 870 short leaf 1,310 and 690 hondo 1,310 and 650 poplar 1,100 and 450 cedar 860 and 350 w cedar 800 and 350 in an effort to determine the accuracy of my primary source I thought Ild look at another source suggested by another member from the wood explorer weight ( specific gravity ) Hondo .57 yellow pine .55 short leaf .44 poplar .38 cedar .33 w cedar .29 bending strength yellow pine 14,117 short leaf 12,834 hondo 11,575 poplar 9,435 cedar 8271 w cedar 5,098 crushing strength hondo 1,548 yellow pine 941 short leaf 804 poplar 490 cedar 485 w cedar 304 hardness hondo 1,006 yellow pine 942 short leaf 676 poplar 432 cedar 337 w cedar 322 impact strength /inches yellow pine 31 short leaf 32 poplar 23 hondo 21 cedar 17 w cedar 13 shear strength yellow pine 1,633 hondo 1,532 short leaf 1,362 poplar 1045 cedar 945 w cedar 875 stiffness yellow pine 1,971 short leaf 1,715 poplar 1,506 hondo 1,353 cedar 1,189 w cedar 1011 work to max load yellow pine 9 short leaf 8 poplar 8 cedar 7 hondo 7 w cedar 5 so what is the superior wood by weight ok not a great way to measure superiority in building characteristics as some measurements translate better than others but still some good food for thought. Im going to look at the average weight of each material as derived from both data sets and compare that to a theoretical sample piece of similar weight and suggest that if a one sq/ft piece of yellow pine one inch thick weighing 3.17 lb is compared to a equal mass piece of poplar and also cedar ; what would ( roughly ) the resulting strength characteristics of each be based on its additional thickness. Yellow poplar would be 1.43 inches thick and cedar would be 1.71 inches thick to obtain the same mass sample of all three species at 12x12 inches. Now I realize that there is some gaping flaws in comparing these data points this way but for the most part its just a theoretical look at strength vs mass as opposed to strength vs volume, the later of which is what both the data sets are based on. averaging the two data sets yellow pine 38 lb/ft3 hondo 37.5 lb/ft3 short leaf 34 lb/ft3 poplar 26.5 lb/ft3 w cedar 23 lb/ft3 cedar 22.25 lb/ft3 long leaf yellow pine is 1.3% hevier than honduran mahogany 18% hevier than its short leaf cousin, 43.3 % heavier than poplar 70% hevier than eastern white cedar and 71% heavier than western red cedar so how do the numbers compare to an equal weight of each material. Ill convert the wood explorer data set to reflect and equal mass instead of an equal volume and then see how that stacks up against the US navy numbers all numbers are converted based on an equal weight of material bending strength short leaf 15,155 poplar 14,143 yellow pine 14,117 cedar 13,520 hondo 11,772 w cedar 8,666 crushing strength hondo 1,574 short leaf 945 yellow pine 941 cedar 829 poplar 702 w cedar 516 hardness hondo 1,023 yellow pine 942 short leaf 798 poplar 619 cedar 576 w cedar 547 impact strength short leaf 38 poplar 33 yellow pine 31 cedar 29.5 w cedar 22.1 hondo 21.35 shear strength yellow pine 1,633 cedar 1,616 short leaf 1,607 hondo 1,558 poplar 1,497 w cedar 1,487 stiffness poplar 2,158 short leaf 2,024 cedar 2,033 yellow pine 1,971 w cedar 1,718 hondo 1,376 work to max load cedar 11.97 poplar 11.5 short leaf 9.44 yellow pine 9 w cedar 8.5 hondo 7.12 placement based on statistical average short leaf 2.1 poplar 2.9 yellow pine 2.9 cedar 3.3 white cedar 5.6 Honduran mahogany 4.1 now the US navy numbers fiber stress at proportional limit yellow pine 9,300 short leaf 9,086 cedar 9,063 hondo 9,000 poplar 8,741 w cedar 8,330 modulus of rupture short leaf 1,510 yellow pine 14,700 poplar 13,184, cedar 13,167 w cedar 11,560 hondo 11,329 modulus of elasticity poplar 2,149 short leaf 2,077 yellow pine 1,990 cedar 1,915 cedar 1,581 hondo 1,454 stress to proportional limit w cedar 2.48 cedar 2.46 yellow pine 2.44 short leaf 2.28 poplar 2.15 hondo ( data not available ) stress to maximum load short leaf 13 yellow pine 11.8 cedar 9.92 poplar 9.74 w cedar 6.9 hondo 6,9 impact bending at proportional limit poplar 19,345 short leaf 1,604 yellow pine 15,400 cedar 14,706 w cedar 12,920 hondo ( data not available ) impact height to failure short leaf 39 yellow pine 34 cedar 29.07 poplar 28.66 hondo 22.4 w cedar 22.1 shear parallel to grain poplar 1,576 short leaf 1,545 yellow pine 1,500 cedar 1,471 w cedar 1,360 hondo 1,332 hardness parallel to grain yellow pine 870 short leaf 814 poplar 645 hondo 661 cedar 598 w cedar 595 placement based on statistical average short leaf 1.9 yellow pine 2.2 poplar 3 cedar 3.5 white cedar 4.9 hondo 5.2 characteristics as compared to cost what is the cost of the 3000 bd/ft Ill be needing and what would that cost be once adjusted to obtain similar strength characteristics based on going back to the original numbers and considering the percentage of increase to achieve equality for each material I buy dead clear straight grained poplar from the mill for less than $1 a foot $2 a foot if I buy it here in town I seem to remember paying about $6 a foot for cedar dead clear old growth straight grain but its been a long time since I bought any so that may be way off ( feel free to chime in with your best price ). Ill go with $5 just to be as fair as possible. long leaf yellow pine is staging a comeback but is still pricey, Ive not bought any except as flooring in a while but even at that its about $2 a foot for #2 common. Im going to say that dead clear straight grain select is bound to be $4 a foot but just to be fair lets call it $3 just in case anyone has a good handle on some. also Im going to consider short leaf and long leaf at the same cost since both are grouped as yellow pine. I’ll price Mahogany at what I paid last for furniture grade select or $6.75 a foot. I went with Steven's suggestion that eastern white was half the price of western red and so considered $2.50 as the going rate per board foot and total for 3000 bd/ft what would I have to spend to get the same strength in each wood in each given category honduran mahogany $6.75 = $20,250 red cedar $5 = $15.000 yellow pine $3.00 = $9,000 white cedar $2.50 = $7,500 poplar $1.50 = $ 4,500 Mahogany based on what I paid for the last pile I ordered which was not specified as honduran. Red cedar Ild likely be paying more like $6 or 7 per ft. Either of the yellow pine brothers, a miracle price, if I could find it, Ild likely be paying more like $5 per ft. Poplar I estimated high just to try and keep things fair, I can buy this material from the mill for <$1 a foot. Eastern white cedar I have no records of purchase to go on cost per 3000 bd/ft adjusted for modulus of elasticity in order of cost poplar = $4,500 long leaf yellow pine - 33% = $6,000 short leaf yellow pine - 17% = $7,470 w cedar +61% = $12,096 red ceder +33% = $20,000 hondo + 0,48% =$21,241 adjusted for impact bending poplar =$4,500 long leaf yellow pine -14% =$7,740 short leaf yellow pine -0.74% =$8,933 white cedar +77% =$13,322 hondo -22.5% = $17,719 red ceder +57% =$23,550 adjusted for static bending to proportional limit long leaf yellow pine -67% = $2,920 poplar =$4,500 short leaf yellow pine -35% =$5,850 white cedar -0.03%=$7345 ceder -0.69% =$14,900 adjusted for shear parallel to grain poplar =$4,500 long leaf yellow pine -36% =$5,760 short leaf yellow pine -19% =$7,290 white cedar -37% =$10,312 hondo - 19% = $16,402 cedar +28% =$19,200 comparison of characteristics by per bd/ft dollar I am recalculating this figure to reflect a comparison to one one board foot material divided by its cost, bending strength per dollar cost poplar 6,290 yellow pine 4,706 short leaf 4,278 w cedar 2,039 hondo 1,780 cedar 1,654 crushing strength poplar 326 yellow pine 313 short leaf 268 hondo 229 w cedar 121 cedar 97 hardness yellow pine 314 poplar 288 short leaf 225 hondo 149 w cedar 128 cedar 57 impact strength /inches poplar 15.3 short leaf 10.6 yellow pine 10.3 cedar 10 w cedar 5.2 hondo 3.1 shear strength poplar 696 yellow pine 544 short leaf 454 w cedar 350 hondo 226 cedar 189 stiffness poplar 1,003 yellow pine 657 short leaf 571 w cedar 404 cedar 237 hondo 200 work to max load poplar 6 yellow pine 3 short leaf 2.6 w cedar 2 cedar 1.4 hondo 1 thing to remember is that some of these numbers do not adjust well to considerations of weight and cost but for the most part I think its a fair way to look at the qualities of a given wood in respect to its use in any building project cheers
| larch on larch ? |
| Ive worked with miles of that stuff still a fir ( usually Douglas rather than larch anyway ) and as such has pretty poor rot resistance and really bad consistency even within the same tree let alone the same forest if Im encapsulating the wood in epoxy anyway then why not a superior wood with the same rot resistance I must admit Im baffled by this fascination with the pines for naval applications once upon a time yellow pine might have been worthwhile but with all the old growth being used up and everything now being farmed its simply doesn't have the characteristics it once had
| oh hey Peter if you get a chance go to a mill thats cutting Larch Fir and check it out huge amount of waste as boards come off the saw they literally curl before your eyes before the next board is cut and stacked over it then there is the stuff that doesn't make it out of the kiln I posted an article around here somewhere about this Ill try and look it up B
| Bos, without going into detail like you did, there is a performance grade of lumber for all common species. Weyerhaeuser calls it performance grade and I knew it as 2400 series lumber. Machine graded for density and it is heavier then standard and tougher to drive a nail--a lot harder. It is used for making floor and roof trusses. Yesterday I was at a truss plant here in Tennessee specifically to look at this lumber and parallelams for boat building. This company is large here in TN. I got quite an education on all products and you can really tell the difference in the denser wood--mostly by weight. It can be bought in 20' lengths down to 4' and 5' lengths used for webbing. It does not change the rot factor though so complete sealing with epoxy is necessary but for strength the density factor is huge. Weyerhaeuser. com talks about performance grade lumber. A couple of pieces I picked up felt almost like ironwood--you could make bats our of it and this was southern yellow pine and spruce-not old growth but the new fast growth seedings (15 years). Just some more info to your excellent posting. Stan I would still prefer Black Locust if I could find the lengths and the price because NO ROT. The lumber above is $.80 to $1.00 a board foot. I fell in love with this boat put a hull like this under your classic and have the best of both worlds. http://www.boatdesign.net/gallery/sh...php/photo/2251 |
| As far as Douglas Fir goes, there's Douglas Fir and Douglas Fir. It's definitely not all created equal. I remodeled old homes in Los Angeles from the early 1900's, and the old-growth DF they were built with had nothing in common with the stuff you see at Lowes or Home Depot. The grain was so tight it looked like a series of pencil lines spaced a line's-width apart, instead of having big, spongy masses of springwood--like plantation DF has. It was so hard that I often had to drill slightly undersized holes to get nails into it (I assume it must have been green when originally nailed together). If I had access to old-growth DF like that, I wouldn't hesitate to use it structurally or any other way, anywhere in a boat. As I've mentioned before, many of the old West Coast lumber schooners were Douglas Fir from top to bottom.
__________________ "All one has to do is follow the plans and build in no permanent leaks." -Charles Minor Blackford, on the simplicity of building flat bottomed boats |
| all true but we are talking about a modern cold molded hull Dougy is heavy it splits splinters and it twists more often than not, it was used because it was so common. Not because it was the superior wood. these days I have good access to just about all the domestic hardwoods and at dam low prices. the frustrating thing is that of all the woods Ive looked at Poplar comes out on top in nearly all categories both in bang for the buck and in most other regards specially when compared by weight lb for lb is it vastly superior to almost all the firs in nearly all categories
| here is more info on poplar.http://www.connectedlines.com/wood/wood79.htm |
And it's also an excellent finish wood. to quote the WWPA, "Douglas Fir's characteristics make it ideal for joinery: doors, millwork, window and door casings, mantels, stairs and baseboards. When dry, it retains its shape and size and won't check or show a raised grain. Additionally, Douglas Fir has an excellent performance record when used in exposed applications for exterior trim without ground contact." I'm not the Messiah of DF. I don't care whether you use it or not, and I'm sure there are more cost-effective woods out there for cold molding than decent-grade Douglas Fir. But it works well when used that way. As a matter of fact, the second USS Constellation, originally built in 1853 as the last pure sail US Navy ship, has been rebuilt with Douglas Fir cold molded outer planking. It allowed them to save more of the original framing, which was no longer strong enough to handle another round of traditional planking and fasteners..
| Within the same species there is a vast difference between one board and another if we each arrive with our own boards to compare. I look for densely grained wood, quarter-sawn, free of pitch pockets, shakes, and straight-grained. I prefer it green to begin with. There are still some trees that produce good boards. Hard pines can be found---- sometimes in old beams or posts. Yoiu can simply accept what is on the market and order it delivered---- I suppose for a big project, you have no choice. You receive what the industry calls "fir" or "yellow pine". The truth is, you have to become an expert at choosing good boards. That means knowing what to look for, not the wood's name, but the actual plank or board. It can't be taught in a book. Some of you know what I mean. Novices will have to learn the hard way, the school of hard knocks. Working with wood involves more than technical information. Like playing a musical instrument, some of the knowledge comes through years of trials and tribulations. Even all this good advice is general, and exceptions abound. Go with the consensus for now, but one day, years from now if you stick with it, you'll develop another sense of wood that is better than any general knowledge available. |
| Cold-Molding Over Planking? | rfnk | Wooden Boat Building and Restoration | 6 | 09-22-2008 11:53 PM |
| Cold-molding over planking | rfnk | Sailboats | 6 | 09-20-2008 12:49 AM |
| cold molding over cedar strip | octavius | Fiberglass and Composite Boat Building | 7 | 06-26-2008 04:00 AM |
| Cold Molding Advice | stuart | Wooden Boat Building and Restoration | 17 | 01-16-2005 11:39 AM |
| Monocoque cold-molding sailboat | jusembo | Boat Design | 4 | 10-04-2004 01:15 AM |
