Old 08-02-2002, 03:43 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 85 Posts: 397
What is "linear urethane"?
Here's a quote from YachtSurvey.com
It got me wondering, wat is "linear urethane"? Some sort of paint or?
Cold it really replace Gelcoat and could it be used in the same way , i.e. applying in a female mold befor the laminating begins?
"It's time to give up on gel coat and start painting boats with linear urethane like Hatteras does"
I'll look for a link to hatteras website, but if anyone has it post it here please.
BTW Yachtsurvey.com has some useful info
Erik
Old 08-02-2002, 07:59 AM
I believe the linear urethane Hatteras uses is called Awlgrip, and is applied in a post-molding application. Hatteras, I believe uses a sandible gelcoat for the in mold, gives it a light sanding, then applies the Awlgrip. The "linear" term, I guess, means the molecular structure is more linear than crosslinked, meaning it will be more durable and flexible than standard gelcoat.
Old 08-16-2002, 08:15 AM
hello;
I'm in the marine paint and epoxy business.
There are lots of different urethanes and polyurethanes, and several kinds of linear (poly) urethanes. Awgrip is a linear polyester polyurethane. So is LPU 100 by progressive epoxy.
the polyerster polyurethanes are probably the best of the urethanes...
paul
