Old 06-14-2011, 05:33 AM
yaasaay yaasaay is offline
Rep: 10 Posts: 53
what is the difference between liquid filler and powder filler?
hi guys
can you tell me
and What are the uses of it?
and
which is better for a surface boat?
Old 06-14-2011, 08:37 AM
Rep: 1493 Posts: 7,447
Can you be more specific on the products you are referring to? Is it a spray fairing compound compared to a powder load to thicken a resin?
Old 06-14-2011, 10:09 AM
Rep: 10 Posts: 53
today I went to the shopping I asked him to give me filler for fiberglass but he give me a powder filler and said it is the same purpose for making a filler by mixing it with resin
powder slimier to http://www.poliya.net/products/allie...ers_additives/
compared to filler rage gold
http://www.tcpglobal.com/autobodydepot/fillers.aspx
Old 06-14-2011, 04:38 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
One is a pre-mixed, thickened resin; you add a bit of catalyst, mash it up, and spread it on.
The other is a powder that you add to the resin of your choice (usually epoxy) to make it thick enough to hold its shape when you spread it.
Epoxy plus microballoon filler is the usual choice for a boat. The polyester-based car body fillers don't hold up so well in the marine environment.
Old 06-14-2011, 05:14 PM
Rep: 10 Posts: 53
marshmat
thank you for your answer
What to use as a filler? don4465 Wooden Boat Building and Restoration 16 02-28-2010 12:57 PM
Fiberglass filler Jeffery Carson Fiberglass and Composite Boat Building 6 05-26-2007 05:25 AM
Fairing filler...... Roly Fiberglass and Composite Boat Building 8 06-01-2006 02:40 PM
Balsa filler rturbett Fiberglass and Composite Boat Building 1 02-02-2006 04:45 PM
filler for scraps okieman98 Materials 4 12-04-2005 01:45 AM
