| Wet foam stringers I have a 2003 26ft. boat with foam core stringers. I recently discovered that a fish box was draining on top of the stringers and the foam wicked up the water. I have received conflicting opinions. One being, the stringers are shot. The other is that it is harmless. I have cured the water intrusion but I am not sure if I should drill some holes to let the water drain out then patch it up, or do I need to remove the top of the stringers and re-foam them? |
| There is a really good article in the last Professional Boatbuilder about wet cores. They don't seem to change the structural integrity of the laminate. Unless you live in a cold climate where the stringers can freeze, it should be OK.
__________________ Gonzo |
| Wet Foam Stringers I am not familiar with "Professional Boat Builder" do you know how I can get a hold of the article? Thanks so much for your help. |
| Closed cell foam should not whick any water up. If there are empty spaces, then water could get in a just sit. Its a newer boat, so I would thing the foam is closed cell. I doubt there is anything wrong |
| Wet foam stringers Thanks for your reply. |
| Airex and any foam based hull materials | tdamico | Boat Design | 21 | 03-04-2009 07:26 PM |
| Pourable foam, need advice | BustedKnuckle | Materials | 6 | 07-10-2006 08:19 PM |
| Wet but solid stringers. | tuantom | Fiberglass and Composite Boat Building | 3 | 08-15-2005 02:29 AM |
| Wet but solid stringers. | tuantom | Powerboats | 1 | 08-11-2005 01:45 PM |
| Foam Block To Bass Boat... can this be done? | Curious | Fiberglass and Composite Boat Building | 10 | 12-11-2004 06:21 PM |
