Old 11-22-2002, 02:15 PM
turnershells turnershells is offline
Rep: 10 Posts: 22
West Microlight 410 Data
I've been experimenting with airex foam core hulls, and I'm using MGS 285 epoxy thickened with West Microlight thickener.
So far I've found about 3% by weight is good for filling the surface, but what I'd like to find is some technical data ie. percentage microlight/density figures or increase in volume. Couldn't find anything in the West book. Is there anything people know of on the web?
Matt Turner
"Buying tools I don't need with money I don't have."
Old 12-02-2002, 10:01 PM
glasbotomboat glasbotomboat is offline
Rep: 10 Posts: 17
As a former chemist formulating fillers, puttys and high-build high solids formulas, I'll tell you these main points:
You can deviate as much as you need in percentage (3% by weight microspheres is about as much as I used to use in typical fillerswhich equals about 40% in volume if I remember correctly) based on the the performance you want according to the following tradeoffs:
With much filler and less resin, you get:
- higher viscosity for troweling / buildup ability
- better sanding ability
- less shrinkage (not much anyway with epoxy)
But the downfalls are:
- weaker cohesive and adhesive bond (breaks easier and won't stick as well) although not significant.
Much resin with less filler you get:
- stronger, harder fill
- thinner with a tendency to run and drip
- sanding is a @#$%*!! (technical term)
- heavier, added weight
- waste of expensive epoxy
I'd say to load it as much as possible as long as it doesn't cake up, and then skim coat over with a more resinous mix after sanding. - JB
West system old wooden boat. jeff goldberg Wooden Boat Building and Restoration 7 10-01-2005 01:26 PM
buddy boat for wpb to west end may 15? got water? Open Discussion: All Things Boats & Boating 0 05-03-2005 10:29 AM
Data for a VPP? Joakim Sailboats 21 09-22-2004 04:35 PM
Small Craft Data Sheets Hannu Rantala Powerboats 6 07-29-2004 05:59 AM
