Old 10-14-2011, 03:18 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Leon,
I have never hear of woven fiber having a bonding problem, at least not when used properly. But due to the extreme amount of forces you are looking at, it would probably be worth hiring a structural engineer to figure out the best composite schedule. Guesses on message boards just won't do, and any knowlagable person (read engineer) has to consider the liability of having people screaming down mountains on something they worked on.
Old 10-14-2011, 03:24 PM
Leon01323 Leon01323 is offline
Rep: 27 Posts: 88
Hey stumble
Thanks for the reply. Well that gives me confindence to do some small tests. Unfortunaly I can't afford to hire someone for suck a small personal test.
Thanks for the help
Old 10-15-2011, 12:32 AM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
There is no separation when the fiber material is the same. Never it becomes isofthalic polyesters stick with thixotropic. If you do it at some time will certainly have separation
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
Old 10-15-2011, 11:56 AM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Leon,
That board is a beam with a support on ends. Try laying up unidirectional fibers along the length for unidirectional strength topped off with bi ax or WR laid out at 45 degree angle to absorb the twisting.
Foam core might not be the right choice as you will be bolting the wheel assembly. Try high quality marine plywood.
Old 10-16-2011, 05:17 AM
Rep: 27 Posts: 88
Yer this is what the other board looks like from underneath:
So what i should do is gel the mould the apply plain weave for the first layer
http://www.cfsnet.co.uk/acatalog/Pla...s_Fabrics.html
then use Biaxial on the next layer
http://www.cfsnet.co.uk/acatalog/Biaxial_Fabrics.html
and if i do 5 layers which would give me 3 of plain weave and 2 of Biaxial and see how that turns out?
i only used foam core in the start as i thought it would make it stronger ( how i was wrong) i dont need to use it. Im trying to replicate this board
http://www.extremekites.co.uk/mounta...&content=index
they say they do different thickness for different weights and their thickest is 14ply for 70-100kg, It looks like carbon fibre but yet the cost is only £100 so i did not think it was.
Thanks again
Old 10-16-2011, 05:37 AM
masalai masalai is offline
masalai
Rep: 1689 Posts: 7,510
HellsBells, A motorised one of those would be exciting, to say the least... and way beyond my ancient body... - - - Good on you for the adrenalin rush...
Try to be helpful...
Remember that there are at least two sides for every story...
Old 10-16-2011, 06:01 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Originally Posted by m3mm0s rib View Post
TOUNNELS I'm not talking about bottom but only where needed lightweight construction
ITS THE BENDING, TWISTING ,AND GENERAL ABUSE OF A GUY STANDING ON A BOARD !!
CORE MATT SHOULD NEVER BE USED WHERE A PANEL IS BENDING !!!
Making beautiful boats is a passion never a chore !
Old 10-16-2011, 07:27 AM
masalai
Tunnels seems to be on the right track, and to add my penny's-worth? -
- The angles in the board are a weak point and high stress location...
- Make the shape curve so the wheelbase lengthens with additional down-force...
- Solidly link the structure for the wheel assembly and the "shoes"
- Let the middle part of the board do the flexing...
- Design and engineer for flex as a means to disperse the extreme loads...
- Find an engineering student who needs a research project for his post-grad-degree...
Old 10-16-2011, 07:31 AM
Rep: 746 Posts: 785
Yeah, Tunnels right. Spherecore or felt type materials are brittle and should only be used as bulking material in the center.
Looking at the board, the ends are angled sharply. Could be a weak point for plywood core also. Might be good to use solid laminate or maybe veneer as core material.
Give me dimensions. Length, width, height at center with curve, distance between angled ends, wheelbase. I will try some analysis.See if a core would be beneficial. The core is used for stiffness and/or to make it light.
It seems that the site is saying plain weave is 0/90 degree fabric. You should be looking for fabric that runs only in one direction, stitched together at 90 degree.
Your lay up schedule should be, Biax, Uni,Uni, Uni, Biax. always a "balanced laminate".
A 0/90 plain weave fabric can be used as a substitute for biax if you cut it in bias. That is, cut it at 45 degree angle at the width you intend to use. Just need careful handling as it stretches easily after it is cut as the weave "closes in" when stretched.
  #25
Old 10-16-2011, 08:15 AM
Rep: 27 Posts: 88
haha ive got a petrol powered one as well but its looking a bit sorry for its self.
ive just found that my supplier does not do uni directional but found another that does
http://www.ecfibreglasssupplies.co.u...00mm-wide.aspx
really appreciate the help and so far that lay up sounds like a good place to. start. Those pics are with the dimensions as far as i can tell/
Thanks again
  #26
Old 10-16-2011, 10:37 AM
old one !
double bias uni uni uni uni double bias not biaxle
  #27
Old 10-18-2011, 11:24 AM
Rep: 746 Posts: 785
Leon,
I ran a quick check and it shows deflection is not a problem.
If you are going to jump on the middle for test, say 2 x your body weight, the board should be at least 4.5 mm. thick with the following layup schedule. Starting from top, Biax 600, 3x Uni @ 600 grams/m2 each (or total 1800 grams/m2 if you are using a different weight), 2x Biax 600 on the bottom.
You need 2X 600 gr. on the bottom as it is in compression. Fiber is weaker in compression plus it loses its directional strength when rotated from the zero reference.
You need to laminate with minimum resin. Try for 50% fiber content or better.
It was analyzed using polyester resin and it seems that I am getting up to 36 N/mm2 of stress. Polyester is allowed only up to 13.8 N/mm2. Epoxy has better strength.
A better analysis would be to try to break the board by jumping on the angled ends at the same time. This is representative of actual use. The ends are cantelevered design with elastic restraint and should be analyzed as such. I am not, at the moment able to do so but you should be safe with the laminate schedule I gave.
  #28
Old 10-18-2011, 02:57 PM
Rep: 27 Posts: 88
Thanks alot I have just got to order the weave. Thanks alot.
Are 2 layers of wax and 2 layers of release sufficient? Bill Brasky Fiberglass and Composite Boat Building 8 07-31-2010 02:14 AM
CSM and roving Bluedesign Boat Design 1 05-21-2007 04:37 AM
CSM Veil Bullseye Fiberglass and Composite Boat Building 4 10-18-2006 06:11 PM
CSM/WR vs Stitched Bx/Qx MattStudent Fiberglass and Composite Boat Building 2 04-20-2006 09:50 AM
What weight & weave fiberglass? drs3317 Fiberglass and Composite Boat Building 0 12-04-2004 08:33 AM
