Old 05-01-2006, 12:25 PM
mcollins07 mcollins07 is offline
Rep: 156 Posts: 206
Water stained wood.
I have had experience with light wood being unwantedly stained with water on a water ski. I bleached it and sanded it with some success. It was a lot of work, and I was not able to completely remove the stain.
Now I am considering the purchase of a hurricane damaged boat. The interior has been flooded with about a foot of water and the interior walls stained. What are my chances of success in removing this waterline mark?
What techniques have been tried? Which ones worked? Any recommendations?
Old 05-01-2006, 12:49 PM
Robert Gainer Robert Gainer is offline
Designer/Builder
Rep: 44 Posts: 142
If this was a diesel powered boat and the engine oil is what made the stain I don’t think you will be successful at all. If it’s just a water mark you will need to clean as much as possible and then stain everything to match. You can’t clean a stain like this to be as good as new.
Good luck and all the best,
Robert Gainer
Old 05-04-2006, 08:44 AM
Rep: 1493 Posts: 7,447
One way to do it, is to clean, degrease and strip all the finish. Then stain everything a bit darker and blend in the stains. It's what a friend of mine calls "an optical solution"
Old 05-04-2006, 09:34 AM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 574 Posts: 274
How about wainscoting -- or paint and a chair rail.
Old 05-05-2006, 05:47 PM
Rep: 156 Posts: 206
Thanks for your suggestions. I'm not sure what I will use yet.
Michael
How much wood (would a wood chuck ..)? Square feet/meter DanishBagger Materials 8 02-17-2006 08:32 PM
How do I keep the wood looking like wood? Laeelin Boatbuilding 9 06-12-2005 09:42 PM
No water in oil pan, But water in oil filter? midtower Gas Engines 14 03-19-2005 05:43 PM
stained glass boat models Guest Marketplace 6 09-14-2003 07:22 AM
Fuel, water, black water tank construction kudu Boat Design 12 07-25-2003 06:54 PM
