Old 02-21-2009, 08:57 PM
duyukof duyukof is offline
Rep: 10 Posts: 2
Waht's the intention to apply different grade material on vessel
According to the ABS rule, different part of the vessel should be applied different grade material, for example, if the whole strength deck is 30mm thick, within 0.4L amidship the deck should be 30AH, and outside 0.4L amidship should be 30DH, but 30AH and 30DH have the same thickness, yeilding point and ultimate point, and they both may service in the same enviroment (both are strength deck). So, why the rule require diferent grade material in the different parts like foregoing says?
Old 02-24-2009, 07:42 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
Check their CVN (charpy V-notch) values, these are different.
apply polyester resin gaffer Fiberglass and Composite Boat Building 19 09-04-2008 01:57 PM
Best way to apply gelcoat? SpecialEd Fiberglass and Composite Boat Building 2 07-27-2007 09:26 PM
How to apply fibreglass tissue? frosh Fiberglass and Composite Boat Building 3 04-04-2006 05:54 AM
Exterior Grade Plywood Chapman Wooden Boat Building and Restoration 5 02-28-2006 12:21 PM
IMS, Where can I find info about what rules apply? (NT) Sailboats 2 01-28-2002 09:55 AM
