Old 09-07-2011, 09:59 PM
Michail Michail is offline
Rep: 15 Posts: 54
Thank you for the information!!!
Old 09-07-2011, 10:58 PM
FMS FMS is offline
Rep: 125 Posts: 233
I have never seen anyone use any kind of "paint" for a binding agent between wood and Polyester or Vinylester before.
How great is the cost differential between epoxy and Vinylester in your country?
Here I remember 25 years ago it was something like $29 for poly and $89 for epoxy so I used poly for small boats and a deck I built. It worked or I should say it didn't fall apart under the use I put them to which wasn't heavy.
Now everything has gone up, but epoxy has actually gone down in price. With the cost of marine plywood nowadays it doesn't make sense to use anything but epoxy here.
Old 09-07-2011, 11:56 PM
m3mm0s rib's Avatar
m3mm0s rib m3mm0s rib is offline
Rep: 31 Posts: 111
Here in my country the price of ethylene-vinyl and epoxy is about the same. It is 15-20 euros an kg. But structures have changed. Place timber on transom and only at certain points in the deck. The reason is that the wood rot and have problems. All the beams is a polyester and one with the hull, thereby ensuring longer life and greater rigidity
m3mm0 SR ib http://www.youtube.com/watch?v=5kwlNk7-iSg
Old 09-08-2011, 08:05 AM
Steve W Steve W is offline
Rep: 360 Posts: 686
Tunnels, FYI, DB1708 is NOT 0/90, it is 45/45 with a .75oz mat which is exactly what one should use for tabbing in and ideally for all the seams on stitch and tape although with most small boats its obviously not neccesary,actually DB1700 is better with epoxy,no need for the mat. Im not disputing that epoxy is the better choice when tabbing in wood, just that its not the only choice and im sure you know that epoxy does not penetrate any significant amount into the plywood on face grain,it is a surface coating and that is fine so no i see no reason to downgrade to 3 ply. I must say it kinda suprises me that you are such a proponent of epoxy for everything being a Kiwi. When i started boatbuilding in NZ in the early 70s we used what was appropriate for the task at hand and it wasnt always epoxy, even though it had been in common use since probably the 50s so it was just one of the arrows in the quiver, on cold molded boats we laminated frames,stem,floors,transom,deck beams and did our scarfs with resorcinal, glued stringers to the frames and the first diagonal skin to the stringers stem and backbone and transom with epoxy and laminated the skin with resorcinal,sheathed with dynel or glass cloth with epoxy,most interior gluing was done with either epoxy or Aerolite UF glue, it wasnt until i came to the US where epoxy was a newer thing in boatbuilding where i encountered the one size fits all, epoxy for everything mentality.
Steve.
Epoxy versus vinyl ester Roly Materials 66 10-10-2010 11:40 PM
Various Vinyl Ester Resins Holiday Materials 8 12-05-2008 10:42 AM
Compatability of vinyl ester and polyester Johnny P Materials 1 10-08-2007 08:41 AM
Isophthalic resin vs Vinyl Ester Dresca Materials 7 06-17-2007 06:43 AM
Skin coating in Vinyl Ester Dresca Materials 3 05-26-2007 04:28 AM
