Old 06-07-2011, 10:45 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
No bogging or fillet with medium epoxy? Really?
I find myself waiting impatiently for epoxy most of the time. I always use fast when coating and sometimes use fast for cove joints if it's a little cooler out.
Why wait around forever for the stuff to full cure? If I use fast or medium, after sitting out in 100 deg temps all day, my part is ready for full loading or sanding the very next morning. Makes for a much more efficient work schedule.
I only use the Sys 3 Gen Purpose epoxy (medium and fast) for coating and bogging. It's flexible, so it's great for those applications.
I use Sys 3 Silvertip for laminates. It's completely different stuff. Wets out really well and has 1/2 hour for fast and a full hour for slow at 77deg F. Of course, it goes faster in the heat, but it's just fine.
I prefer to use the General Purpose medium and fast so I don't have to waste time post curing. The slow hardener for System 3 Gen P is the only epoxy they make that requires a post cure. I'd rather not waste all that time post curing. It's only for bogging and coating, so no reason not to use it.
I did a cove yesterday (101F again) using medium and it came out beautifully.
Kurt Hughes was right about this place.
Old 06-07-2011, 11:36 AM
You know what? I think I did an extra large batch that time too.
In the future, I'll just do the smaller batch, apply, form cove, mix a new batch, continue cove, repeat until cove is done.
I really don't want to post cure.
Old 06-07-2011, 12:31 PM
Thanks. Actually, the last bulkhead went in yesterday (for this hull). This does not count bulkheads that are inserted attached to beams. Those go in during hull alignment later.
Old 06-07-2011, 04:39 PM
Who am I talking to here?? Where did all of bntii's posts go?!?
Old 06-07-2011, 06:48 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
I hear you cat, got my note book.
Old 06-07-2011, 07:16 PM
bntii's Avatar
bntii bntii is offline
Rep: 1073 Posts: 704
Ha!
I was in a foul mood working in the heat on some boats today...
I distrust anything I say when off my oats & thought I was lecturing so I dumped the whole lot.
The good news I finished off the day milling a nice bit of corian for around the galley sink on our boat.
Good on ya Cat- I can't wait to see the launch photos.
Old 06-07-2011, 07:20 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Whew! I am relieved to see that post, bntii.
Hoyt
Old 06-07-2011, 08:26 PM
Is that what gentlemen do? I usually leave my rants and off color posts up for all to see!
I didn't see anything foul or wrong with your posts, for the record. They seemed ok to me.
Oh well. Glad you're back in the thread.
Launch photos will be quite a long time away. I only have one hull nearly done! Still another to go, plus beams, boards, rudders, bridgedeck, house, final fairing and painting, outfitting for splashing, etc...
Originally Posted by bntii View Post
Ha!
Old 06-08-2011, 10:50 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,684
Originally Posted by ondarvr View Post
For about every 15 degrees you increase the temperature above 77 the gel time is cut in half.
For every 15 degrees below 77 the gel time is about doubled.
Does the quality of the cure remain the same with the different gel times?
  #25
Old 06-08-2011, 11:19 AM
I really am enjoying FL's weather for building boats.
Now, with the air conditioner, I can take the building and bring any humidity down to about 50%-60% in a matter of an hour or so. The temperature over the whole building doesn't change much, but the 14" duct blows a heck of a lot of cold air right on you and/or your work area used for spot cooling. You can throw the duct into the hull and the whole hull comes down to a temperature that even I, from the north, get cold in.
I can work out there in any temperatures, so long as the working area is small. This is very different from last summer's learning curve.
I'll be doing rudders, dagger boards and main beams this summer in a small "tent inside a tent" in order to control the temperature and humidity for those projects. The next hull will be done in the fall when the temperatures and humidity go back down - when rainy season ends.
I usually start in at 5AM or 6AM, with the air conditioner started an hour before.
I then do my work/laminations until early afternoon, at which time I let nature "post cure" my layup. I turn off the air conditioner in the afternoon and allow temps to climb to 100 degrees F (38 deg C) all afternoon long in there, really locking in my work.
It's really working out well. The air conditioner has allowed me to produce perfect quality work all year 'round instead of just in the winter.
  #26
Old 06-08-2011, 04:41 PM
hoytedow's Avatar
Resistor
Thereby effectively close to doubling your build speed, no?
Hoyt
  #27
Old 06-08-2011, 04:55 PM
Not doubling, but maintaining it at full capacity year round instead of struggling in the summer and ending to with poor quality.
  #28
Old 06-10-2011, 02:51 AM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
In your climate, I would not worry about postcure. This is a one-time operation, which can be done by putting the thing in the sun, turn it around a couple of times. (hope it will be sitting on a trailer of some sort) Or just let the temperature rise as much as possible for a couple of days.
Humidity is accelerating epoxy. It also can make coatings cloudy, so use a fast hardener for that.
As for the 2 bottles: If you want to be absolutely sure, do a side-by-side test, with equal amounts. The colour does not say much. They are specified as "Gardner colour" and can range from clear to dark brown. Some epoxy resins can really differ from batch to batch.
  #29
Old 06-11-2011, 07:59 PM
Alan.M Alan.M is offline
Rep: 27 Posts: 37
That'll do it every time.
  #30
Old 06-11-2011, 10:17 PM
ondarvr ondarvr is offline
Rep: 288 Posts: 662
Not really, in general the cooler the temp, the longer the gel time, the poorer the cure.
Tubby Tug- and some variations of it. newinertia Boat Design 2 12-26-2008 09:12 PM
Downeasters, keel variations and following seas YankeeBoater Powerboats 2 09-27-2006 04:41 AM
Need info on manufacturer greenham64 Powerboats 0 05-24-2005 03:43 PM
Info on manufacturer? Kovas Powerboats 3 04-09-2004 09:23 AM
manufacturer requirments... Boatbuilding 3 02-10-2002 11:44 PM
