Old 09-15-2004, 01:37 PM
brevell brevell is offline
Rep: 10 Posts: 3
Vacuum bagging with fabric
I'm a dinghy sailor for hobby and do window treatments for income. I'm wondering if the same technique for building a hull would work on a drapery rod problem. I'd like to laminate fabric to a fluted wooden pole about 2"in diameter and thought the vacuum bagging process might draw the fabric down into the flutes or depressions in the pole. Can you point me to websites or tutorials regarding the vacuum bagging process and materials to use to make the fabric adhere to the wood? Thanks , Burt
Old 09-15-2004, 02:16 PM
AVMan AVMan is offline
Rep: 10 Posts: 29
Vac Bagging a Pole
One word of advice, if you try to bag a traditional glass fabric around the outside diameter of a pole, when you pull a vacuum the fabric will have a tendency to lose section (become thinner) and instead of filling the flutes it may wrinkle (fabric becomes longer/wider when it thins out). I guess if you do some trial and error you can find out the exact length of fabric to use (less than the circumference) and actually have the wrinkles go into the flutes.... You might also want to try braided tubes (chinese finger traps) if the fabric doesn't work.
As for bagging research, try Gouegeon Bros, Airtech, Richmond Aircraft Supply...
Hope you can make some sense out of my ramblings...
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
vacuum bagging or vacuum infusion Eisa Hasan Fiberglass and Composite Boat Building 10 03-29-2005 04:25 PM
Vacuum bagging bulkheads tbot Fiberglass and Composite Boat Building 4 03-11-2005 08:00 AM
Vacuum Bagging Question turnershells Boatbuilding 0 01-20-2003 01:33 PM
