Old 01-13-2012, 08:58 AM
wharris87 wharris87 is offline
Rep: 10 Posts: 2
Use of Soric core in conjunction with ISO 12215-5
Hi,
Does anyone have any experience of specifying a laminate that complies with ISO 12215-5, when using a Lantor Soric core?
does that core count as a bulking material, or should it be assumed to be a sandwich core?
Any advice would be brilliant!
cheers,
Will
Old 01-13-2012, 01:12 PM
Herman's Avatar
Herman Herman is offline
Resininfusion.info
Rep: 1043 Posts: 1,268
Why not contacting Lantor direct? I have found them very helpful.
Old 03-09-2012, 08:33 AM
fcfc fcfc is offline
Rep: 359 Posts: 709
Did you got an answer ?
I mailed them for the very same question about Soric LRC, but did not got an answer.
NB For SF and XF have a shear strength > 3 N/mm˛, so may be OK to be used as bulking.
For LRC, shear strength is lower, and published data is still preliminary.
BTW, are there other products bulking material/infusion media in small thickness ?
Thanks.
Old 03-09-2012, 08:56 AM
Herman's Avatar
Resininfusion.info
I have a bunch of 3mm Core-Cell A500 in double cut configuration, which could do the job.
Otherwise you end up with either Soric-like materials or Rovicores. The latter being weighty. (fills 100% with resin)
soric core material printing thru??? harrier spiro Fiberglass and Composite Boat Building 10 07-23-2011 08:56 AM
ISO 12215-5 problems killwater Boat Design 7 01-21-2011 12:05 PM
ISO 12215-5..is needed ringoo83 Boat Design 0 10-14-2010 01:42 PM
Iso 12215-5 ? fcfc Class Societies 11 10-31-2009 11:49 AM
Iso 12215-7 sholt85 Class Societies 1 03-24-2009 01:31 PM
