Old 08-29-2003, 03:55 AM
E.V.O. E.V.O. is offline
urethane
Hi. I would like to build a boat, using foam in the core.
I am about to make the form in which i want to spray the foam.
But the foam will stick on to the form, isn't that right ?
What can I put between the foam and the form to prevent this. ??
Erik
Erik
Old 08-29-2003, 06:44 AM
Rep: 1397 Posts: 7,215
I don't think the foam you are referring to is structural. Also, the resin may disolve it depending on the chemical composition. The boat designer should have specified the type of foam.
Old 08-29-2003, 06:49 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
Er... seriously
You can't build a boat that way!
There are exellent links on this site to lots of information about building boats. Buy books on the subject or borrow at the library if available.
Spray cores aren't really that good for boatbuilding anyway.
Erik
Pourable foam b_rodwell Materials 39 12-18-2009 08:31 AM
Teen Restoring 16' Fiberglass Boat, Need Help djkingmatt Fiberglass and Composite Boat Building 28 04-18-2006 02:29 PM
polyester matrix over urethane foam tjantti Materials 0 09-21-2004 05:21 AM
Urethane as a replacement for Gelcoat? turnershells Materials 0 09-11-2003 11:25 AM
