Old 07-19-2009, 06:10 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
U bolts or weld trailer
this is a nine m trailer I am making to carry long plates
the gvm will be 2.8 tonnes
I need raise the deck above the tyre tops, which means another shorter chassis rail under the main rail
the main rail is 150 x50
the rail to run under 100 x50
I can do two things
weld it under
or use U bolts say 4 per side, the extra rail 2.0m say 14mm bolts The lower rail should I know be twice as long, but the darn money for another 8m steel, and the tare weight keeps rising
Tandam axle , given that trailer axle kits are usually supplid with 4 u bolts each axle , which are usually 10mm
I could then shift the axle config fore and aft if necessary
thoughts please
this will also be a mobile cutting table
Old 07-19-2009, 07:56 PM
nero nero is offline
Rep: 112 Posts: 624
Hey whoosh,
Go look at a semi trailer. They have a mechanical sliding unit that shifts the tandems. Since you are trying to gain height something like this would be ideal. You may even find an old trailer and get the slides off of it.
regards
Old 07-19-2009, 08:02 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by nero View Post
Hey whoosh,
regards
give me a yell here when you are inside, will call you
Old 07-20-2009, 02:33 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
Replace the sq tube with two rect tubes side by side to the tow hitch to form the front triangle - it will be stiffer and provide better support for the hitch's bolt down.
Personally I would have used channel instead of tubing. It would last about 4000 times longer and comes out at the same weight. Weld a flat bar on the top side of the frame front to back. Stiffen the trailer quite a bit.
To space the frame over the axle - which I hope is a rub axle(s) you chose - you can use two V's either side. If you put any more supports on the axle they can be vertical posts only. The V's will keep them upright. The V's should have side swing support as well wrt the trailer frame, to make sure the load won't bend the V's when you corner.
I would weld the V's to the trailer, but bolt to the axle. 4 x 16mm bolts washers and nylocks both sides.
My trailer had drum brakes, what a load of crap. Worked only for ten minutes then needed some adjustment. This I ripped out and installed disk brakes made out of Mazda and Golf parts, available for relative inexpensive.
Will never build a trailer without disk brakes again. Only a pleasure. Even on a steep downhill and a heavy load you don't know you are towing something.
Regards
Fanie
Water ! Just gimme water !
Old 07-20-2009, 03:14 AM
Previous Member
Rep: 0 Posts: 0
I built 25 nine m trailers) al al for big boats I only wanted know about the u bolt idea, will use one disced axle, , and go back to 2 tonne
thanks fanie, the structure aint finished, go shoot something
Old 07-20-2009, 03:47 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1298 Posts: 1,991
What type of axle kit? This might make it easier..
Old 07-20-2009, 03:54 AM
Previous Member
Rep: 0 Posts: 0
teddy!! it is what we call a walking beam axle config(rocker roller)
how are things, in the North, did you shoot a Mosse or a Ruski!!
Old 07-20-2009, 12:43 PM
TeddyDiver's Avatar
Gollywobbler
I'd like to sometimes... but generally we shoot moose.. and maybe a reindeer if it's not our herd
boat trailers made from wood/ no weld metal trailers blackdaisies Boatbuilding 44 10-21-2011 09:18 AM
outboard bolts Winner bassboat Outboards 2 03-25-2008 04:07 PM
Transom Brace Weld LAURASDAD Metal Boat Building 8 03-01-2007 10:23 AM
Weld or Bolt Richard & Diane Metal Boat Building 4 08-30-2006 08:30 PM
Give me 5minutes and I can teach a monkey to weld rOx-Weld Boat Design 0 02-07-2004 04:20 PM
