| Two questions: polyester + polyurethane foam & any underwater use contact adhesives? 1. How well does polyester resin adhere to the 'skin' of poured polyurethane foam ? ( if at all ! ) 2. Are there any contact adhesives that are usable for underwater use ? |
| 1. It doesn't adhere very well, but you can use an intermediate layer of Sika-290 primer to improve adhesion. 2. There is liquid neoprene, used by Mercruiser to seal bellows to the alloy housing. It is also used to repair inflatables.
| Thanks CDK, I've noted those suggestions. |
| Polyurethane foam water absorption | Mr Efficiency | Materials | 30 | 12-23-2010 04:36 PM |
| Polyurethane Foam | Bart01 | Boat Design | 65 | 10-10-2008 01:52 PM |
| Polyurethane Foam install | Ok J | Fiberglass and Composite Boat Building | 5 | 04-20-2006 02:45 PM |
| Welding polyurethane foam and such... | jprev | Boatbuilding | 11 | 01-31-2005 10:28 PM |
| polyester matrix over urethane foam | tjantti | Materials | 0 | 09-21-2004 04:21 AM |
