Old 03-09-2011, 05:09 AM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Trim tabs for Aluminium boats
Is it ok to use stainless steel trim tabs on an aluminium boat that will spend much of its time in the water?
If not... any suggestions? I looked at the QL interceptors, but by all accounts they would better suit a higher speed boat - this one operates at quite low planing speeds
Old 03-12-2011, 11:04 PM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
yes pretty much all aluminium boats use them
do not forget that your anode is your protection against the electrolytic action
You could achieve a total mech isolation with bushes and gaskets but really there will be no trouble
Old 03-12-2011, 11:12 PM
IMP-ish IMP-ish is offline
powerboater
Rep: 68 Posts: 238
Maybe not the right shape, but the Bennett sport tabs have a black finish. I painted mine 5 years ago to match the same black/shine of my drives. But the black base coating from their factory has not come off at all in 10 years. The "ram" cylinders are plastic.
Old 03-13-2011, 03:31 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Aluminum tabs would be a much more logical choice.
One could argue that the boat becomes a giant sacrificial electrode for the stainless tabs, but the difference in surface area will probably reduce the effects.
Old 03-13-2011, 03:42 AM
Hägar Hägar is offline
Rep: 95 Posts: 19
Well
pretty much NO producer of the standard flavour uses them. So, how did you collect your information?
As CDK said, AL is the more logical solution.
Hä Hä Hägar
Old 03-13-2011, 09:26 AM
tabman tabman is offline
Rep: 24 Posts: 20
The black powder coating on the Sport Tabs acts as insulation between the stainless Trim Tabs and the aluminum.
Stainless Steel Trim Tabs are indeed used on many aluminum boats. We supply many aluminum boat builders with Trim Tabs to be installed at the factory as well as many aftermarket owner installations.
Insulating the Trim Tabs from the boat with non-conductive materiel, taking care to insulated the fasteners and installing zinc anodes on the Trim Tabs will prevent electrolysis from damaging the boat or the Trim Tabs.
Since the application is on a lower speed boat make sure to select Trim Tabs that are on the larger size of the manufacturer's guidelines.
Tom McGow
Bennett Marine
Old 03-14-2011, 04:07 AM
Rep: 109 Posts: 242
Thanks everyone. Clearly, I'd choose to use aluminium or composite tabs if they were readily available (why aren't they???). By the sounds of it, I'm down to just isolating and coating the stainless ones to the best of my ability...
Trim tabs 640 blazer Powerboats 4 03-18-2010 04:25 AM
Trim tab options between bennett and kplanes? Lenco trim tabs? Red Tide Powerboats 5 11-19-2009 06:59 AM
Trim Tabs Poida Wooden Boat Building and Restoration 6 12-23-2006 06:34 PM
Trim tabs John Perry. Marketplace 1 09-17-2005 08:11 PM
Trim Tabs stevel Powerboats 0 09-20-2004 03:13 PM
