Old 05-22-2004, 04:50 PM
guest12020101217 guest12020101217 is offline
Rep: 10 Posts: 40
Trevira Core 150
Can anybody help me?
I have been looking and looking for properties of Trevira Core 150 ( a non- woven core polyester". I know it is used by some builders in euorpe and have been told that is supplied by Johns Manville in the USA. Sady l cant find a thing about it on the website and have never recivered a reply to may e-mail.
Does anybody have values for the following?
Tensile and Compressive Strength
Tensile and Compressive Modulus
Density
and anything else.
Old 09-10-2004, 04:42 AM
Rep: 66 Posts: 640
Ever since I saw your post I've been trying to find some info!
I now it's being used in boatbuilding, but I'm drawing a blank here to.
Sorry.
Maybe you should try here:
http://www.treviracs.com/englisch/contact/contact.htm
Dutch Peter
Old 09-10-2004, 08:58 AM
Try www.marinecomposites.com under the "materials" chapter page 76. It gives some properties of Trevira Core 100 (bulker mat similar to Coremat, only made with polyester fibers):
Tensile Strength: 2700 psi
Compressive Strength: 17700 psi
Shear Strength: 1800 psi
Flex Modulus: 443 psi x 10^3
Cured Density: 75 lb/ft^2
Dry Thcikness: 0.100"
Hope this helps.
Structural Foam mistysea Materials 6 05-10-2010 09:58 AM
Wet Balsa Core Cliff Ruckstuhl Materials 2 07-11-2005 08:14 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Use of wood as core in polyester jfblouin Materials 24 02-20-2005 09:38 AM
A new type of core? Fred Boyle Materials 7 01-06-2005 11:25 AM
