Old 01-23-2011, 02:05 PM
fishhawk fishhawk is offline
Rep: 10 Posts: 5
transoms
HI, im new to this forum, i have a 21' wellcraft, 18" setback transom w/ 6" hyd.jackplate and 150 merc efi. my transom is rotten, since i have a lot of experence with epoxy and glass work im going to re-build it myself. i,ve seen some repair shops that use 1/4" luan plywood (phillipine mahogany) saturated with slow setting epoxy and f.g. mat untill they build up to the desired thickness. i'd like some opinions on this as opposed to using layers of 3/4" marine plywood thanks fishhawk
Old 01-23-2011, 02:16 PM
Rep: 670 Posts: 2,457
About half way down this document is the description and repair technique recommended for transom core replacement.
http://www.westsystem.com/ss/assets/...aintenance.pdf
Old 01-23-2011, 05:03 PM
Rep: 3125 Posts: 9,399
Assuming a 1.5" core (two layers of 3/4" plywood), you can save some money with 6 layers of cheap 1/4" lauan, though it's likely not as strong as the two pieces of marine grade 3/4", in spite of all the mat and goo.
On highly loaded transoms I use three layers of 1/2", with the grain oriented at 12 degrees to each layer (further increasing strength). Since you use epoxy, you know that you don't need, nor is it desirable to use mat. I laminate each layer in place on the boat, typically with through bolts or temporary screws to hold everything together as the goo sets up. Then of course the tabbing to the hull shell.
The basic issues with the cheap lauan from Lowe's?depot is the glue used may not be WBP and the thickness of the long grain veneers. This isn't an issue with marine grades. Some will have you use a BS-1088 grade, which is fine, but unnecessary on a transom, so save some money and use a BS-6566 grade plywood.
Old 01-23-2011, 06:04 PM
Rep: 1493 Posts: 7,447
Two layers of 3/4 is how iI always do it. I agree with par on the rest.
Old 01-23-2011, 06:18 PM
Rep: 10 Posts: 5
thanks for the advice, the original transom was 2" guess i'll go with 4 sheets of 3/4, as the weight of the setback is about 100 lbs, the jackplate about 50 lbs. and the engine 450lbs, and its sitting 24' back.
Stepped transoms tkinak Powerboats 37 03-10-2010 11:27 AM
Stepped or pocket transoms? MIKE I Boat Design 6 10-02-2009 07:43 AM
Should I dry out my transoms plywood core before closing? sbklf Materials 4 01-05-2007 07:32 AM
Transoms-fiberglass powerboats tonyg1178 Fiberglass and Composite Boat Building 4 09-17-2005 03:22 PM
Transoms andrew Fiberglass and Composite Boat Building 4 11-02-2004 02:30 AM
