| Tinting gelcoat. I hope you guys can make sence of this here goes. I have 3 gal of neutral gel coat unwaxed and 1 gal of white unwaxed to spray my boat.I mixed half the blue tint that was recommended for one gal to one gal to get a sky blue at 3% tint...didnt work so I mixed in another full gallon of neutral to the previous gallon and its still way to dark leaving me 2gal for above the rub rail. I may have messed up a little they said no more than 6% colorant and I just assumed 3% would lighten it up alot but it didnt.Should I add some of the white to the 2 gal of blue mix to get the sky blue that I want and what would be a close ratio.and I need a Light gray for above the rub rail how much black tint to the white gel coat should I add?I will spray two coats below the rub rail to the hull sky blue and and one waxed coat for above the rubrail. flybridge and aft cabin everything.The hull I will brush on later. Material I have. 3gal neutral gelcoat unwaxed 1gal white gelcoat unwaxed blue colorant white colorant black colourant MEKP acetone 1qt styrene wax Will I have enough gel coat ? I have a 2.5qt pot gun and 2mm tip. Its going to be cold 60 degrees tomorrow would it be wise to go 2.5% catyalist or will it set before the pots empty?
__________________ 1978 Bayliner Victoria 2750 |
| Mixing dupont 380 I have this product in a quart can ,,,like a fool I applied it directly with a foam brush.....you can imagine the results....it tells me to thin it out with lacquer3602S.... I don't have a spray gun to apply any suggestions....??? Thanx Dave Moody |
| Less colorant will make it more translucent but not much lighter. You need to use a lighther blue tint or add white.
__________________ Gonzo |
| Too bad about the Brewers,,,I'm watching Texas I hope they win but st Louis is good.. I need to thin out the gelcoat... I'm starting to touch up the faded gelcoat on my 1976 Kingfisher..... |
| Tinting gelcoat possible with this method? | Wynand N | Fiberglass and Composite Boat Building | 7 | 07-30-2010 09:37 AM |
| Gelcoat tinting - Here I go again, hopefully i'll get it right this time. | Dan H | Fiberglass and Composite Boat Building | 5 | 09-12-2009 08:39 PM |
| Tinting gelcoat for a re-color | Dan H | Materials | 9 | 09-09-2009 07:30 PM |
| tinting PU varnish ? | M-Sasha | Materials | 11 | 03-06-2009 07:33 AM |
| Spraying gelcoat over gelcoat | alexhiguera | Fiberglass and Composite Boat Building | 9 | 08-26-2005 10:09 PM |
