Old 06-09-2011, 02:58 AM
rsimon rsimon is offline
Rep: 10 Posts: 27
Thru hull spacer material
The plan is to install this male threaded thru hull onto a 90 deg. female elbow fitting so as to bring a hard line assembly up above the water line. My hull thickness (the sides of the hull) is 1/8". The securing nut only goes up so far onto the threads leaving a good 1/4" space left...I won't be able to tighten it up against the hull from the inside. I was considering using a hardwood or even aluminum for a spacer to act as sort of like a washer. Any ideas?
I hope this these pics help:
http://i1216.photobucket.com/albums/...s/2e3725a2.jpg
http://i1216.photobucket.com/albums/...s/193b08c6.jpg
http://i1216.photobucket.com/albums/...s/32b62681.jpg
Old 06-09-2011, 03:44 AM
anthony goodson anthony goodson is offline
Rep: 241 Posts: 391
Good morning
Here in the UK we would go to a plumber's merchants and buy some thick neoprene or rubber washers.
Old 06-09-2011, 05:14 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Check standard garden hose washer for size. It looks like it may be close. You may need 2 to get it thick enough.
Hoyt
Old 06-11-2011, 11:24 PM
Rep: 10 Posts: 27
Rubber washers
The Maeleron fitting is bigger (diam.) than garden hose washers. Also, it has to absolutely water tight (over time as well.) I was thinking of something harder like a plate of aluminum or some sort of composite wood to in effect shim the hull make it artificially thicker than the 1/8" it is. Maybe IF I found the right diam. rubber washer that fit tight around the mushroom/fitting end without any gaps(leaks) I could stack those washers to take up the space. Can I use 5200 over rubber? Responses are appreciated. Rog
Old 06-12-2011, 05:48 AM
Rep: 241 Posts: 391
It doesn't need to be that tight on the mushroom fitting ,it seals on the flat surfaces.
Old 06-12-2011, 06:02 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
Are you wanting some material to just seal the gap or something as a backing plate the strengthen the very thin 1/8th hull.
A hull strengthening backing plate of some sorts would be used by a professional builder on such an application like marine ply wood epoxied on.
Old 06-12-2011, 11:23 AM
Rep: 1493 Posts: 7,447
You need to use a bedding compound rated for underwater use. Also, the threads don't go to the end because there is a backing plate required on the inside if the hull is so thin. Otherwise, it will end up leaking and the hull may fail too.
Old 06-12-2011, 11:45 AM
Rep: 10 Posts: 27
That's my question, what would you use as a backing plate: wood or composite plastic or aluminum? (my hull is 1/8" aluminum.) Is 5200 rated for underwater use?
Old 06-12-2011, 08:58 PM
Yes 5200 will do fine Aluminum would work. Make sure you put 5200 between the backing plate and the hull too.
Old 06-13-2011, 12:04 AM
Rep: 10 Posts: 27
Thru-hull spacer
Thanks, I was leaning towards going with the aluminum spacer as a back plate for that. I will take your advice with the 5200 between the spacer and hull too.
which hull material jbehr Sailboats 43 10-06-2010 09:58 AM
Self Sealing Hull Material DrCraze Materials 41 06-26-2010 05:14 PM
HDPE hull material lascraigus Materials 7 01-15-2010 04:01 AM
Hull Forming Material Fanie Boat Design 8 10-28-2007 05:00 AM
Hull building material and techniques. DJPierrot Boatbuilding 3 06-25-2004 07:32 AM
