Old 06-25-2005, 10:19 PM
Jeffrey Jeffrey is offline
Rep: 10 Posts: 10
Thinning core bond putty?
I used Arjay's 1041 light weight core bonding putty to vacuum bed some Nida-Core. I have a few gaps about 3/16" wide and 1/2" deep. Can these types of putty be thinned out with resin and catalyzed so you can get better flow?
Jeff
Old 06-26-2005, 12:06 PM
John ilett's Avatar
John ilett John ilett is offline
Rep: 23 Posts: 131
Maybe your laminating resin could be thickened instead to bed the core into, with vacuum I am sure this should work. I was always under the impression that core bonding pastes are often intended for bedding cores with vibrating rollers or similar.
Structural Foam mistysea Materials 6 05-10-2010 09:58 AM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Use of wood as core in polyester jfblouin Materials 24 02-20-2005 09:38 AM
A new type of core? Fred Boyle Materials 7 01-06-2005 11:25 AM
Bamboo Core - What's Wrong With Idea? James Mills Boat Design 11 07-13-2004 11:27 PM
