Old 08-18-2005, 12:57 AM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Thickness of aluminum cat hulls
If I am using type 5052 H32 Aluminium/magnesium alloy to build catamaran hulls, is .125 thickness adequate for a robust hull, assuming all curves, and bulkheads at a minimum of 5 feet on center? Also, can this material endure without coating it?
Also posted on metal boatbuilding forum.
Old 08-18-2005, 06:13 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
What do you scantling calculations tell you?
Old 08-19-2005, 07:18 PM
imagineer
Rep: 58 Posts: 436
I can't find a precise definition for "scantlings". Where's that BoatDesign.net glossary? Can you explain scantlings?
Old 08-24-2005, 06:03 PM
D'ARTOIS D'ARTOIS is offline
Rep: 311 Posts: 1,069
For your purposes Jonathan, 4mm minimal thickness is required, 5 mm would be better. The hulls are stiffened in the longitudinal way sufficiently by the top mounting bracket and the long rubstrake along the hull.
Since those hulls have to carry only weight distributed over the whol length, more reinforcements are not required save for some bulkheads to keep you afloat at a collision. And there have been taken provisions for.
Thickness of aluminum cat hulls? JonathanCole Metal Boat Building 4 08-18-2005 11:17 PM
Aluminum hulls artdeluxe Sailboats 28 07-05-2005 08:52 PM
Welding Speed for Aluminum Hulls jprev Metal Boat Building 3 11-06-2004 09:31 PM
Structural Foam for Aluminum Hulls jprev Metal Boat Building 3 08-30-2004 09:51 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
