Old 12-12-2003, 02:52 PM
slneatboat slneatboat is offline
Rep: 10 Posts: 12
Thickening Gellcoat
Does anybody know if there is an additive or filler that can be added to gellcoat to make it into a putty like substance.I also want the gellcoat to retain its original colour in this case white and be as water proof as its orginal state if possible.Thankyou
Old 12-12-2003, 05:13 PM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
You can add microballons (hollow glass bubbles) this will thicken it up! It is a more expensive option but sands great. It will be somewhat more porus tho. So plan on a topcoat with surfacing agent. I don't know what kind of volume of mix you need but it takes alot to bring it to a fairing putty stage. You might just use epoxy then topcoat with your gelcoat
Good luck 8Knots
Old 12-13-2003, 12:43 AM
Rep: 1397 Posts: 7,215
Fumed silica (Cabosil or Aerosil) works well.
