Old 01-19-2004, 05:11 AM
steve66 steve66 is offline
Team Philips Catamaran
I am currently studyiny for my degree and am investigating the major failure of the Team Philips catamaran hull. Is there anyone out there who can offer me any help on this area, i.e. possible reasons for the failure such as delamination of the composite material as a result of incorrect storage and processing of the material which is one of the areas I have been investigating.
many thanks steve
Old 01-19-2004, 11:14 AM
nico nico is offline
Rep: 52 Posts: 186
What are u studying?
____________
Nico
Old 01-19-2004, 01:24 PM
Unregistered
marine and composites design
Old 01-19-2004, 03:38 PM
ClarkT ClarkT is offline
Rep: 10 Posts: 96
From what I've heard, your on the right track with that thesis.
Try contacting the designer in person. You can find Adrian Thompson's address through www.vsvboats.com
I'd also contact the folks at SP who should have a lot of guidance for you, not to mention a good job prospect when you get your degree.
-ClarkT
Old 01-19-2004, 05:21 PM
Morgig Morgig is offline
Rep: 10 Posts: 50
I would agree that talking to the designer is the good place to start. However I would suggest you look at the big picture and consider the load case, factors of safety, weather conditions in which the vessel failed etc, before focusing in on a particular theory of why Team Phillips hull failed.
Morgig
Old 01-21-2004, 01:03 PM
Rep: 10 Posts: 96
Ouch Morgig! It's a 3 hr class, not a dissertation! Give the guy a break. I think there is plenty out there for him to learn and report about in the study of the laminate failure due to QA oversights. It's going to be one general paper with no time for specifics if he tries to build a global model of the failure.
-ClarkT
Old 01-22-2004, 06:15 AM
Rep: 10 Posts: 50
My mistake, I assumed this was for a dissertation, not a 3 hr class, if that's the case yes you would have to focus in on one area.
Morgig
Old 01-22-2004, 07:11 PM
John Perry John Perry is offline
Rep: 44 Posts: 75
I heard it said that it was at least in part due to expansion of air within the nomex core blowing off the skins, the construction team being previously used to working with foam cores where the air is contained. I would have thought the vacuum bag neg pressure should have been well in excess of the warm air pressure (pv=rt), was the problem during post cure without vacuum?
Old 03-05-2004, 05:17 AM
Daints_99 Daints_99 is offline
Rep: 10 Posts: 2
Tp
I have spoken the Adrian Thompson about this very subject, and like a lot of things the failure started with the finances, the lack of funding for a project of this nature ment they had to cut corners, you only have to look at the build shed for the project, when using such materials as carbon fiber, ytou dont want to be builing an a dusty cold shed with leaves blowing about, corners have been cut !!! look at the masts and rigging, they were built with stress sensors in them, but what good are they if they arnt wired up and theres no software to monitor them. This is a subject that i feel very strongley about as i belive she was and still could be such a fantastic record breaking boat and would love to see her built again with more funds and then got out and prove all these sinics wrong !!!!
Old 03-11-2004, 09:19 AM
Patrick Fitz
hi guys im 14 and i have been reading the book THe Race and i was wondering if one of u guys would mind giving me a quick explanation of how team philips was able to go faster than the wind i under stand how to sail and all that great stuff but i am totally lost with the idea of sailing faster than the wind ok thanks guys (o and im 14)
Old 03-11-2004, 11:41 AM
Rep: 52 Posts: 186
Nice question, the idea to grasp is the difference between true wind speed and apparent wind speed. The true wind speed is the wind speed u feel at rest. But when the boat is moving towards the wind (say 80°) the wind speed u feel is higher (the boat speed + a component of the true wind speed) = apparent wind speed. It means that u can sail in 10 knots of true wind speed, and have an apparent wind speed (the wind speed that the boat/sails see) higher than 10 knots. Which gives enough forces to the boat to sail faster.
So the boat can sail faster than the true wind speed but not faster than the apparent wind speed.
Hope this helps, and hope my english is not too bad
____________
Nico
Old 03-12-2004, 12:22 AM
Daniel Cohen Daniel Cohen is offline
Rep: 10 Posts: 2
As ive sailed on a fast 76 foot cat at over 30 knots haveing a mast flying around over head at high speed is the most un nerving thing I can imagine .A bad idea tons moving one way and the boat going the other
Old 08-01-2004, 01:21 PM
SilverWolf SilverWolf is offline
Rep: 10 Posts: 2
Hi
The problem with team philips is the design. It was designed by a submarine designer, so it was not built to withstand the immense wave pressures at the surface. You must remember that there are no waves and no winds underwater, just a constant water pressure. the designer allowed for o margin, but not enough. For example, the hulls were designed to withstand 5 tonnes waves, which really is not enough, and without the front beam to transfer the force to the other hull, the hull tips were squeesed together untill the port holl snapped. I do not believe that it was a build problem. if it were, other yachts built by goss would also fall apart, and thankfully they don't
Silviu
Old 08-01-2004, 01:24 PM
Rep: 10 Posts: 2
Oops! I read the wrong end of the forum. Sorry!
Old 08-01-2004, 04:07 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
I didn't know Adrian had designed submarines... Aqua Quorum certainly didn't look or behave like one
Steve
Join in a Co-operative Catamaran Build Venture! Neven Marketplace 0 12-17-2004 02:20 AM
Team Philips Exhibition at National Maritime Museum Cornwall zctpv58 Boat Design 0 10-13-2004 11:35 AM
Electric motor revolutionizes catamaran sailing Jason Stevens Motorsailers 0 05-11-2004 09:10 AM
Team Adventure (110' RACE cat) returns brian eiland Open Discussion: All Things Boats & Boating 0 04-10-2004 09:54 AM
Team Philips Daints_99 Sailboats 1 10-28-2002 07:41 PM
