Old 11-04-2006, 03:55 PM
Man Overboard Man Overboard is offline
Tom Fugate
Rep: 129 Posts: 246
Teak deck laminated with epoxy
Will a teak deck laminated in place using epoxy (no fasteners), delaminate in the tropics do to heat?
Tom
Old 11-04-2006, 06:35 PM
Gypsie's Avatar
Gypsie Gypsie is offline
Rep: 50 Posts: 98
The wood moves and the epoxy does not, something has to give. Use Sika 298 with appropriate primas and follow the instructions and all will be fine.
Randall
International Marine Consultant
PH: +62 812377 61277
www.randall.asia
Old 11-05-2006, 01:23 AM
Rep: 2891 Posts: 8,796
Epoxy, under teak will reach 150 degrees in the tropics, which is the point it begins to loose it's grip on things. This coupled with the poor performance of epoxy with teak and other oily woods, forces me to recommend a polysulfide. There are several available for this task, 298 is well recognized in the industry.
Synthetic teak deck dmc Materials 74 08-07-2010 06:50 PM
Teak deck caulk now available Teakdeck Marketplace 1 02-23-2007 04:56 PM
repairing the deck with poly or epoxy? fishweed Fiberglass and Composite Boat Building 5 09-07-2006 09:38 AM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 08:47 PM
Teak deck laid in epoxy Guest Boatbuilding 5 07-09-2003 05:21 AM
