Old 10-24-2011, 06:59 AM
metin_mehel metin_mehel is offline
mech.eng.
Rep: 10 Posts: 92
suitable wood for hard chined sailing yatch
Hi guys,
I want to build a hard chined sailing yatch (7.5m loa) what are the types of wood suitable for stringer?
Thank you very much?
Old 10-24-2011, 06:28 PM
Rep: 1493 Posts: 7,447
There are many. What can you get locally? If the designer already specified the species, that is what you should use.
Old 10-24-2011, 07:05 PM
Rep: 3125 Posts: 9,399
To follow Gonzo's comments, if the species the designer has suggested isn't locally available, then select a different species with similar physical attributes, that is available locally.
Old 10-25-2011, 12:16 AM
mech.eng.
Rep: 10 Posts: 92
I am the designer. I can localy find spruce(picea) {400$/m3 unmachined stocks}. After selecting suitable wood I can make a finite element strength analysis to hull. But some times woods have suprising properties that I don't know. Moreover could you advise me a book which tells the properties of woods about boat building.
Thanks a lot.
Old 10-25-2011, 12:46 AM
Each area of the world has woods that are preferred for boat building. I'm not sure what's available in your country, but most have forestry services of some sort and this agencies produce directories of the commonly available woods, listing their physical properties.
Try this link www.thewoodexplorer.com and see what's available in your area. FEA usually isn't necessary, with some familiarly of your local species offerings.
Old 10-25-2011, 03:36 AM
mech.eng.
Rep: 10 Posts: 92
spruce(picea) I can find it. What do you think? Is this suitable for stringers and chine log?
Old 10-25-2011, 02:08 PM
It depends on the design and the quality of the timber. Honestly, if you have to ask those questions, you are not ready to design a boat.
Old 10-26-2011, 12:48 PM
rxcomposite's Avatar
rxcomposite rxcomposite is offline
Rep: 746 Posts: 785
Here. From a very old LR rules on Wood & Composite. I have another book but have to find it.
suitable wood for hard chined sailing yatch-pic008.jpg  suitable wood for hard chined sailing yatch-pic009-1.jpg  suitable wood for hard chined sailing yatch-pic010.jpg
Old 10-27-2011, 10:00 PM
HakimKlunker's Avatar
HakimKlunker HakimKlunker is offline
t=pc squared ?????
Rep: 111 Posts: 171
Somewhat agreed. With less direct words: Your design requires a structural calculation and so you need to know the material properties.
If they are unknown, you first need to study the materials before you can take the next step.
Unless - - - you declare your boat experimental or for racing purposes and then you can crack it which ever way you please and you are still CE conform
Productive suggestions to consider:
Your wood needs to take the expected loads. This will result in appropriate dimensions;
Your wood needs to be either durable or well protected.
Your wood needs to be available, treated and stored correctly (Termites, Humidity, warp, etc)
Your design needs to consider conservation in terms of coating but also geometry to i.e. avoid condense water build up
There is perhaps also a decorative aspect
Old 10-28-2011, 02:33 AM
Rep: 670 Posts: 2,457
There are beautiful wooden boats built in Istanbul. Ask the builders what local wood they use, then cross reference for suitabilty. I believe locust, cypress , oak and a very dense pine are commonly used in turkey
Old 10-29-2011, 07:49 AM
Is that cypress similar to american cypress?
Hard wood flooring for strip built kayak? brucegseidner Materials 8 12-17-2009 04:25 PM
Round bilge or multiple hard chine on Sailing yacht ???? tang Sailboats 12 10-07-2007 04:15 PM
hard-chined 24' ply/glass sailboat- question molerocket Boat Design 14 08-10-2006 12:16 AM
hard to find U.S. made cut thread wood screws luke bronco Boatbuilding 9 11-29-2005 04:59 PM
Soft bilge hull vs. Hard chined. Are both seaworthy? tdamico Boat Design 34 08-31-2003 08:11 PM
