Old 09-01-2008, 05:17 PM
Meanz Beanz Meanz Beanz is offline
Boom Doom Gloom Boom
Rep: 585 Posts: 2,286
Sugar Deck
Anyone tried doing a 'Sugar Deck" with epoxy resin? Results?
For those not familiar a sugar deck is a non slip created by putting sugar over the last coat of resin then dissolving it out leaving a grippy resin surface. I have never done one, just been told, I believe its a technique pioneered by custom surfboard makers and used later by custom sailboard makers.
Old 09-03-2008, 04:53 PM
mikereed100 mikereed100 is offline
Rep: 30 Posts: 82
I used to do this when making sailboards and recently used it when repairing the cockpit on my boat. I like it because, as you point out, it dissolves away leaving a nice, non-lethal surface. I used sand on the decks of my old wooden boat but the paint always wore out over the grains which allowed water under the paint and it would flake off. It was also hard on the knees of my levi's.
Mike
Old 09-03-2008, 05:07 PM
Hey Mike...
So it works with epoxy, no nasty arcane reasons or reactions not to do it?
Cheers
MBz
Old 09-04-2008, 03:01 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,025
Hey Meanz, it makes a "sweet" non skid, sorry couldn't help it! All the best from Jeff.
Old 09-04-2008, 03:27 AM
I lick it! errrrrr like it.
Old 09-04-2008, 05:17 AM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1474 Posts: 1,620
Sounds feasable
i will give it a try when i get to some painting etc. in about a months time
keep you posted
Old 09-04-2008, 02:06 PM
Rep: 30 Posts: 82
Meanz,
I never used sugar with epoxy but I'll bet it works. Better try some on your neighbor's boat first just in case.
Mike
Old 09-04-2008, 03:46 PM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
hahhahha "sweet non-skid" hahha ,,,,,,,so how do you dissolve the sugar,,, or does the heat from the resin do it,,,,,,
be freakin funny wake up in the mornin and see ya deck full of every bird and sea animal within 50 miles, licking the paint off,,,hahaha
hehe ,,,,,Jim------>
Old 09-04-2008, 05:27 PM
Hot water works...
Old 09-04-2008, 05:28 PM
Yeah that's my take... I will do a test patch first!
Old 09-04-2008, 05:36 PM
tinhorn's Avatar
tinhorn tinhorn is offline
Rep: 272 Posts: 553
hahahahahaha!
Old 09-05-2008, 01:21 AM
kengrome kengrome is offline
Rep: 287 Posts: 719
I use sifted ground rubber in paint.
If by 'resin' you mean epoxy, epoxy is supposed to be covered with something like paint to protect it from UV, so I fail to see how the paint will avoid getting into the holes left by the dissolved sugar ... ?
Kenneth Grome
Old 09-05-2008, 02:52 AM
waikikin's Avatar
Ants love sugar so we call this slip resistant coating "ANTI-SLIP"!!!!!!!!!!!!!!!!! the method used to be common in varnish on sailing dinghy floors/soles. All the best from Jeff.
Old 09-05-2008, 02:54 AM
A sugar deck is done as a final coat, its not painted over, the sugar is laid on top of, not mixed into the resin... the surface wears down and needs to be redone generally before the resin gives up. So if epoxy lasts as well as polyester unprotected it should be OK... it could be done with pigmented resin but I know nothing about what pigments work with epoxy... I might just stick to using polyester, maybe try a sugar deck with flow coat.
Anyway its tried and true by the surf and sailboard crowd... leaves a very nice deck, not to lumpy but grippy enough.
Old 09-05-2008, 02:57 AM
LOL.... humour, must be beer o'clock!
Yeah... so I believe, varnish is not right for my job but I suppose there is nothing to stop you doing it with a number of coatings.
Wanted - More HP for 18' Sugar Sand Jet (210HP) CoughlinTR Jet Drives 0 08-12-2008 11:36 AM
adding a sugar scoop to 46ft cross tri mpsm1957 Multihulls 8 09-10-2007 11:52 AM
swallowtail sugar scoop kettay Sailboats 10 07-29-2007 12:09 PM
What's under my deck??? hapaboy Boatbuilding 4 10-22-2006 05:04 AM
Want to replace old Mako 19 deck with a "Flats boat deck" - am I crazy or what ! dan Boatbuilding 4 09-24-2002 03:48 PM
