Old 12-16-2004, 06:22 PM
Igor Kaputnik
Substituting shaft types
My plans call for a shaft of aquamet 19, but I want to use something stronger, such as aqauloy 22. I cant imagine there would be an issue using a stronger shaft but I figured I should find out for sure. What are thoughts of the group??
Thanks
Igor
Old 12-17-2004, 02:10 AM
Rep: 1623 Posts: 2,343
Just email the manufacturer with your requirements and check, should be ok. Be aware that the materials get harder but more brittle with the higher numbers so you can't always simply swap materials.
You will find both Aqualloy and Aquamet on the web.
Mike Johns.
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 09:02 PM
Shaft design Danielsan Boat Design 4 09-23-2004 10:25 AM
Propeller shaft bearings, whirling vibration christos Powerboats 3 05-08-2004 08:42 PM
Keyed to Splined Propeler Shaft CaptPPan Powerboats 1 03-15-2004 09:38 AM
rudder shaft and tube Kenny B Marketplace 0 07-08-2002 10:30 PM
